by OnoSendai » Wed Jul 27, 2016 6:30 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.41_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.41.tar.gz
IndigoRenderer4.0.41.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.41_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.41.tar.gz
IndigoRT4.0.41.dmg
Changelog:
4.0.41
* GPU PT: Fixed problem with Phong nkdata materials as children of non-basic materials.
* GPU PT: Fixed some bugs that sometimes caused crashes in realtime changes with GPU enabled.
* GPU PT: Changing e.g. the substrate material of a coating will correctly trigger a GPU rebuild.
* Made it so that texture exponent -> texture roughness conversion is only effectively applied if roughness param is actually edited in UI.
* Improved texture exponent -> texture roughness conversion.
* Made some scene nodes (render settings and tonemapping currently) be serialised and saved in IGI files.
This allows tonemapping settings, whitepoint, curves etc.. to be saved and loaded with the IGI.
* Bumped IGI format version to 8.
* Made colour curves work with loaded images.
* Made light layer setting updates work for loaded images.
* Added some tooltips for material control.
* Changed label from 'Emission' to 'Emission Mult'.
* Increased blend param step, also made max value 1.0.
fourzeronine
by fourzeronine » Wed Jul 27, 2016 6:58 am
Great!
Is motion blur still planned for the OpenCL path tracer?
Originalplan®
by Originalplan® » Wed Jul 27, 2016 6:50 pm
Wow that was fast!
Thank's Ono!
by StompinTom » Wed Jul 27, 2016 8:55 pm
Quick question about the exponent-roughness switch: does exponent still work, i.e. for exporters? Are there more scene description changes planned? Don't want to go too far in the wrong direction ;)
Also, is there any kind of list of 'minimum features' that exporters should implement? Or a common way of exposing things?
Zalevskiy
by Zalevskiy » Wed Jul 27, 2016 10:08 pm
del
Zalevskiy on Fri May 28, 2021 5:27 pm, edited 3 times in total.
Zalevskiy
by Zalevskiy » Wed Jul 27, 2016 10:11 pm
del
Zalevskiy on Fri May 28, 2021 4:25 pm, edited 1 time in total.
Zalevskiy
by Zalevskiy » Wed Jul 27, 2016 10:19 pm
del
Zalevskiy on Fri May 28, 2021 4:25 pm, edited 2 times in total.
by OnoSendai » Thu Jul 28, 2016 12:27 am
fourzeronine wrote:Great!
Yes.
by OnoSendai » Thu Jul 28, 2016 12:29 am
StompinTom wrote:Quick question about the exponent-roughness switch: does exponent still work, i.e. for exporters? Are there more scene description changes planned? Don't want to go too far in the wrong direction
Yeah, you can still export exponent params from exporters. They will be loaded and render as normal. It's only when you change one of the exponent params in the UI that they are converted to roughness.
If you are targeting Indigo 4 then you should prefer to display and export roughness though.
Regarding minimum features, we don't really have a strict minimum feature set, it depends on the application and what will be important to the users.
by OnoSendai » Thu Jul 28, 2016 12:44 am
Zalevskiy wrote:Ono big thank's! this release is productive
I tested 67 pieces of materials (metals category) in the GPU mode correspond to 100% quality, with the exception of gold, despite the large amount of time to render is a lot of noise:
http://www.indigorenderer.com/materials/materials/65
noteworthy that gold sample 750 / 555 / 333 ... rendered in the GPU mode is excellent, and with the pure gold that something is wrong
Whoops, fixed for next release.
by OnoSendai » Thu Jul 28, 2016 12:51 am
Zalevskiy wrote:
http://www.indigorenderer.com/materials/materials/688
open error:
Error while building scene Error while loading specular material 'glass' Failed to find function 'voronoi(vec2, vec2)'.
buffer, line 52
color2(voronoi(tile(mypos()), mypos()))
Other functions with the same name
voronoi(vec2, float)
voronoi(vec2, vec2, opaque)
I fixed this mat on the MatDB, try re-downloading it.
This one runs out of mem due to too many nk mats
by OnoSendai » Thu Jul 28, 2016 1:06 am
This material looks different than the image on the MatDB in 3.8 as well.
Eneen
by Eneen » Fri Jul 29, 2016 2:40 am
I think, that after editing and saving in .41 material can't be opened, I get error:
Error: Failed to parse material: Failed to find expected element 'diffuse_albedo_spectrum'. (In element 'scenedata / material / phong'): <phong> <diffuse_albedo> <constant> <rgb> <rgb>0.850003814755 0.850003...
Exponent group is removed in mat definition but after adding it manually material works:
<exponent>
<constant>5000</constant>
</exponent>
