That is one sick glass indeed, I wonder if your drink tastes better in it?suvakas wrote:That glass render looks awesome !!
Heterogeneous participating media tests
- Borgleader
Re: Heterogeneous participating media tests
Me face amazed !
That is really, really a nice thing to me !
And thanks for the ISL examples... but function declaration has changed for 2.4, isn't it ?
Little digression then, what's planned for an ISL documentation ? I'd gladly help, at least to motivate it
ISL potential is immense, there must be a proper guide to initiate the clever mind.
I can't get this shader to work with 2.6.1(http://www.indigorenderer.com/forum/vie ... 268#p86268):
I know it is under positional constraints but Indigo rejects the 'shader' tag in the first place. What am I doing wrong ?
The glass shader in the linked page works, only that colors are not blending for me...
<medium>
<name>indigoShader1_medium</name>
<precedence>6</precedence>
<basic>
<ior>1</ior>
<rgb>
<rgb>0.8000000119 0.8000000119 0.8000000119</rgb>
<gamma>2.200000048</gamma>
</rgb>
<subsurface_scattering>
<shader>
<wavelength_dependent>false</wavelength_dependent>
<shader>
<![CDATA[
def eval(vec3 pos) vec3 :
vec3(
if(
dist(pos, vec3(0.0, 1.5, 1.5)) < 0.6,
2.0,
0.0
</shader>
</shader>
<phase_function>
<uniform/>
</phase_function>
</subsurface_scattering>
</basic>
</medium>
<material>
<name>indigoShader1SG</name>
<specular>
<internal_medium_name>indigoShader1_medium</internal_medium_name>
</specular>
</material>The glass shader in the linked page works, only that colors are not blending for me...
Hey CTZn,
when using shaders for scattering it is
not
same goes for <absorption_coefficient>.
<scattering_coefficient>
<shader>
<shader>
<![CDATA[ ... ]]>
</shader>
</shader>
</scattering_coefficient>
<phase_function>
<uniform />
</phase_function>
</subsurface_scattering>Code: Select all
<shader>
<shader>
<![CDATA[ ... ]]>
</shader>
</shader>
<phase_function>
<uniform />
</phase_function>
</subsurface_scattering>Re: Heterogeneous participating media tests
Oh, new tags ! Thanks a lot fused, I overlooked this "detail".
- arc en ciel
Re: continous blend between three different
OnoSendai wrote:In this image, a volumetric shader is controlling the absorption of the glass medium.
It's basically a continous blend between three different absorption colours.
The medium looks like this:
<medium> <name>MedIndigo Material_mid0</name> <precedence>10</precedence> <basic> <ior>1.600000</ior> <cauchy_b_coeff>0.000000</cauchy_b_coeff> <absorption_coefficient> <shader> <wavelength_dependent>true</wavelength_dependent> <shader> <![CDATA[ def col(real t) vec3 : if( t < 0.5, lerp( vec3(100.0, 100.0, 1.0), # blue vec3(1.0, 100.0, 100.0), # red smoothstep(0.25, 0.35, t) ), lerp( vec3(1.0, 100.0, 100.0), # red vec3(1.0, 1.0, 100.0), # yellow smoothstep(0.65, 0.75, t) ) ) def eval(vec3 pos) vec3: col(e2(pos) * 6.0) # + fbm(pos * 100.0, 6) * 0.5 ]]> </shader> </shader> </absorption_coefficient> </basic> </medium>
hi,
i did some images using the code above, I changed value color for smallest, and tweak smoothstep
what real t is ?
how / where is describe color's model precisely ?
what smoothstep is doing exactly ?
all rendering on i7 2.4 ghz ang gpu 780M :
from left to right, textures on mesh : specular, blended specular/Fast SSS, fast SSS
GPU_4m30_1130spp_2105ksps
BiDir_32m_2678spp_662ksps
all fast SSS mat
GPU_20m_860spp_945ksps
GPU_2m25_607spp_2091ksps
recette :
thx, and happy rendering
The col function takes the third component e2() from the position in 3D pos being sampled for input, that is the upwards z vector e2(pos) (counting from element zero).
Smoothstep is just a nicer ramp, aka smooth ramp, as opposed to linear color change. It is used here for remapping purposes based on the z value the function is fed with. I'll leave it here
e: by the way thanks this is useful code I was reluctant to figure out, wherever it came from (e: oh yeah from above like all things ;D)!
- arc en ciel
thank's you very much, CTZn, for explanations, I really appreciate.
do you know that your Passionated http://www.indigorenderer.com/materials/materials/1005 is bugging in gpu mode :
GPU path tracing initialisation failed: clBuildProgram failed: CL_BUILD_PROGRAM_FAILURE
Awesome stuff
With regard to volume data, OpenVDB (http://www.openvdb.org/) seems to be used a lot. I think the Blender crowd is looking at implementing it in some way. Haven't read into it too much yet, though, so may not be applicable...
My materials are getting old, I should review them thank you.arc en ciel wrote:thank's you very much, CTZn, for explanations, I really appreciate.
More detail on Blender + OpenVDB: https://wiki.blender.org/index.php/User ... BRendering
Would be awesome to have support for it, it seems to be gaining traction as a volume format for all sorts of things.
