A diamond ring
A diamond ring
Hi
A diamond ring as a gift!
- pixie
Re: A diamond ring
You spoiler!!
Re: A diamond ring
The 3D models databases are the same for everyone!
- pixie
Re: A diamond ring
And what have you learn from this same model in another studio setup?contegufo wrote:The 3D models databases are the same for everyone!
- Originalplan®
Re: A diamond ring
Lightning isn't good.
Try use a CAM setting with 100ISO and 100exp.
And dimm the lights too till white is white and not gray.
Re: A diamond ring
My studio setup is not a secret. Alternately a semicircular crown emissive a toroid, sometimes one or two light area. Gemstones are particularly difficult materials. I try to do something personal; I think I'm on the right track!
All images have been processed with Photoshop.
- pixie
Re: A diamond ring
Let me rephrase it then, from those two setups which is better and why?contegufo wrote:My studio setup is not a secret. Alternately a semicircular crown emissive a toroid, sometimes one or two light area. Gemstones are particularly difficult materials. I try to do something personal; I think I'm on the right track!
Re: A diamond ring
Hi
This it would be the same as I worked on the levels.
Re: A diamond ring
Another version. the background a bit 'dark wanted to accentuate the contrast between the ring and set where it is placed.
Re: A diamond ring
Hi
The latest versions with two light area and slightly correct levels in Photoshop.
The end result looks decent as regards the gems.
- pixie
Re: A diamond ring
If you wanna check how much contrast one image really have you ought to turn it into black and white, as from you can see there's not much contrast between the ring and the background, either step way up or way down.contegufo wrote:Another version. the background a bit 'dark wanted to accentuate the contrast between the ring and set where it is placed.
Re: A diamond ring
Generally when photographing a gold object with gems using a ring light and dark background as blacks fabrics, velvet and so on.
In some pictures in the gallery Indigo I saw that the backgrounds are blacks.
At this time I started the rendering background with black / graphite.
We wait for the result!
Re: A diamond ring
Hi
Here is the version with black / graphite. The contrast is strong too.
Users browsing this forum: No registered users and 123 guests
