by Oscar J » Wed Jun 01, 2016 7:16 am
Hehe cool, nice caustics! Needs to cook for a little longer though, also I believe that second pic isn't in full size?
arc en ciel
by arc en ciel » Wed Jun 01, 2016 10:13 am
image updated for ray version : logo look better
gpu rendering
kodakchrome 64 and 25 tonemapped
Zbrush and fibermesh test
arc en ciel
by arc en ciel » Sat Jul 02, 2016 12:23 pm
hello
playing with sloppy coating ISL, I found a way to have a result like AO effect or solarize in a certain way
I try the code in exponent when coupled with phong, in sigma when coating is coupled with oren nayar
def eval(vec3 pos) real :
let
c = clamp(meanCurvature(), 0, 1000)
z = normalWS().z * 0.15
z2 = z * z
in
if (z > 0, z, z2) * (noise01(pos))+ (c * (0.5/512))
Original code by fused
- solarizeMetalExponent.igm
- (2.54 KiB) Downloaded 263 times
by pixie » Sat Jul 02, 2016 9:36 pm
arc en ciel wrote:image updated for ray version : logo look better
gpu rendering
it remind me of a kind of puppets we used to make with paper!.
Zalevskiy
by Zalevskiy » Thu Jul 07, 2016 4:13 pm
del
Zalevskiy on Fri May 28, 2021 5:18 pm, edited 2 times in total.
FakeShamus
by FakeShamus » Tue Jul 26, 2016 2:37 am
first time adding something to this epic thread!
I started this as a trial for this quartz material, then realized the effect had a lot to do with how the object was modeled, so that became a whole different set of things to work out. it took a long time to clear up, but the result is not bad!
by OnoSendai » Tue Jul 26, 2016 2:49 am
wow amazing, how did you do it?
FakeShamus
by FakeShamus » Tue Jul 26, 2016 3:20 am
the material is just glossy transparent, with fbm noise controlling the roughness and absorption layer color. the bump is ISL noise too. but I had to "crack" the shard in order for the bottom section to get interesting. so I made a rough-looking plane in blender and gave a it a tiny amount of thickness, then used it to do a difference boolean on the shard a bunch of times. so it went from a very simple model to a pretty complex one real quick.
Originalplan®
by Originalplan® » Tue Jul 26, 2016 7:46 am
FakeShamus wrote:first time adding something to this epic thread!
So cool!Good work!
arc en ciel
by arc en ciel » Tue Jul 26, 2016 10:06 am
FakeShamus wrote:... from a very simple model to a pretty complex one real quick.
Smashing
arc en ciel
by arc en ciel » Sat Jul 30, 2016 5:39 am
sorry for double post
my first image with ies profile
arc en ciel
by arc en ciel » Fri Aug 05, 2016 6:49 pm
a car painted with ISL, a coating with phong in substrate using cartoon contour code mixed with noise in Color channel,
(clouds by CTzN), 2 scatters
def eval(vec3 pos) vec3 :
let
line = (minCosTheta() < 0.015) || (meanCurvature()< - (pi() * 9.0))
in
vec3(
noise(meanCurvature() * 0.7),
fbm(meanCurvature() * 0.005,5),
noise(meanCurvature() * 0.003)
vec3(line ? noise01(0.001) : noise(0.05))
