Hi
The king's scepter Indigo!
Re: The king's scepter Indigo
wow like it, balanced coverage, and sharpness
c4d scene file please
(if it is not a secret)
I have an error message
"The extension c4d is not allowed"
I put the file .igs
I put the file .igs
- scettro.igs
- (25.21 KiB) Downloaded 263 times
- pixie
it's a matter of compressing those into a zip. the igs file most surely won't have any mesh in itself. When exporting a scene save as "pigs", this way it will export textures, meshes, whatever it needs.contegufo wrote:I have an error message
I put the file .igs
Hi
Voilà the file zip.
Increasing from 1 to 10 the value of "precedence" is obtained a greater contrast!
Voilà the file zip.
- scettro.c4d.zip
- (902.37 KiB) Downloaded 271 times
- pixie
There's no reason that precedence has any impact in contrast. Precedence is used when different mediums are used (liquid/solid), not anything else.contegufo wrote:Hi
Voilà the file zip.
Hi
The two glass elements have "precedence" = 10, while in the first immgine = 1. As you can see there is no difference. Perhaps the environment is considered medium equal to the air?
Other explanations?
Other explanations?
- pixie
Indeed, when you set "precedence = 1" you're making it like air, and got those two as if they were the same medium.contegufo wrote:Hi
Other explanations?
