Firstly, congratulations on the V4 !
I'm a little confused about the Pure GPU rendering in the Cinema 4D plugin version (Not the standalone).
When I installed the V4 windows version, I was offered to install the Cinema 4D plugin, which has a 3.X number.
Inside, there is an option for GPU rendering but is this the new Pure GPU rendering mode, or the old Open CL/ Cuda slight acceleration ?
When I installed the mac version, I wasn't offered the plugin.
Is the Pure GPU mode in the plugin yet & if so in both mac & windows or just windows ?
Thanks for your help.
									Pure GPU rendering in the Cinema 4D Plugin
Cinema4D R13 Studio, Indigo RT, Zbrush4 R3
Re: Pure GPU rendering in the Cinema 4D Plugin
An updated Cinema 4D version is coming soon afaik.
						- pixie
It's curious that from within cinema plugin the problems I have on standalone doesn't show up. The GPU isn't used above 40% though, it seems as if the previous gpu is being used.
						- pixie
It seems to be indeed the case as normal maps are working...pixie wrote:It's curious that from within cinema plugin the problems I have on standalone doesn't show up. The GPU isn't used above 40% though, it seems as if the previous gpu is being used.
Thanks, I think you're right.
I guess I can setup in Cinema then render in standalone for now.
						- Originalplan®
Well it is the "old" GPU rendering inside the plug. AKA you can use 1 GPU.Decade wrote:Firstly, congratulations on the V4 !
But export the scene to Indigo App and render there. + you got plenty of features there too.
Yep, thats what I plan to do for the minute. I just wanted to check I had it right.
						- Originalplan®
Yep you got it right. Go for it!
Users browsing this forum: No registered users and 69 guests
