Actually it was Nick telling me I did the floor all wrong. :DOriginalplan® wrote: Thank's Oscar i try my best. Fused i heard that name before......but why am i picturing a laughing white little cloud :D.
Nice scene optimizing! You need to teach me some tricks sometime.
Indigo Renderer 4 public beta
Hi, did the Benchmarks with my two GTX 960,
v4.0.31
Mclaren optimised: 9.322 Ms/s
Bedroom scene: 3.036 Ms/s
is it already possible to upgrade from indigo v3 to 4?
v4.0.31
Did anyone tried to open Indigo 4 with Linux, specifically Ubuntu?
Have you tried the new version, 4.0.31?SreckoM wrote:Did anyone tried to open Indigo 4 with Linux, specifically Ubuntu?
I think it still has problems, we're working on fixing it.SreckoM wrote:Did anyone tried to open Indigo 4 with Linux, specifically Ubuntu?
oh wow update, the GTX260 did build kernels and render the simplest scene (a cube) on 4.0.30, only that it is 3 or 4 times slower that CPU PT :/ I was warned, and that's still a progress.
edit: in fact it is building kernels alright with OpenCL but only the initial samples are shown, render stops immediately with the error reported earlier on bigger scenes. It's loaded and fired though.
ps: i7 860 not listed as a GPU device in the UI, I'm confused whether it should be in the list or not. I'd make nicer cubes renderings :/ If my checking was correct the CPUs are SSE4 dot one compliant as mentioned.
- pixie
Mine is but i've installed the opencl drivers for cpuCTZn wrote:oh wow update, the GTX260 did build kernels and render the simplest scene (a cube) on 4.0.30, only that it is 3 or 4 times slower that CPU PT :/ I was warned, and that's still a progress.
- Originalplan®
OH YEAH!! Nice numbers ^ ^vasco wrote:Hi, did the Benchmarks with my two GTX 960,
v4.0.31
Upgrades should be available on the store sometime tomorrow.vasco wrote: is it already possible to upgrade from indigo v3 to 4?
- Silverwing
If you ever visit Ludwigsburg Germany feel free to visit me in my office for a adoption audition...pixie wrote: You don't want to adopt me? :P
Sorry for the delay here´s the McLaren scene:OnoSendai wrote::)pixie wrote: You don't want to adopt me? :P
Silverwing: please try the McLaren scene again!
With the McLaren scene i get around 32.300 Samples/Sec.
Preparation time was done in about 10sec.
Pretty impressive I have to say :-)
Hello. I'm still have no idea how to use my FX5800. I already had installed latest drivers, but nothing changed.
Probably, someone can tell me what I should to do.
I reinstalled Indigo to 4.0.31, but still the same "no supported OpenCL devices"
GPU not working
GTX 460 2GB GDDR5 256bit
OpenGL 4.1
my 2600K CPU supports the instruction
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
GPU not working
GT 660 2GB GDDR5 192 bit
OpenGL 4.3
XEON 5506
A set of instructions and commands NX MMX SSE SSE2 SSE3 SSE4 SSE4.1 SSE4.2 SSSE3
Your tests are not objective in the resolution 1117 627
Increase the resolution up to 1680 by 1050.
OpenGL 4.1
GPU not working
OpenGL 4.3
XEON 5506
Finally got both scenes rendered now :)
Reduced image size to 0.56 MP (1000x562). Halt SPP 512.
System
Win 7x64 pro
CPU: 2x Intel Xeon X5650@2'67MHz (16 GB RAM)
GPU: NVidia Quadro M5000 (8GB RAM)
McLaren Optimized:
- GPU OCL: min 01:01 sec // 7.599 M s/sec
- GPU + CPU OCL: min 01:03 sec // 7.838 M s/sec
- CPU OCL: min 08:32 sec // 0.684 M s/sec
- CPU (no OCL): min 02:14 sec // 2.156 M s/sec
Bedroom:
- GPU OCL: min 02:47 sec // 2.525 M s/sec
- GPU + CPU OCL: min 02:30 sec // 2.739 M s/sec
- CPU OCL: min 17:49 sec // 0.341 M s/sec
- CPU (no OCL): min 05:04 sec // 0.949 M s/sec
While OCL rendering Bedroom scene i've found that if first image is done with GPU and second with GPU+CPU, rendering hangs while building, as oppose to if started with CPU and secondly CPU+GPU, rendering is done normally.
So i was wondering, since CPU is much slower on Open CL could Indigo be made to work so that both computing units would be rendering simultaneously different images and merging them when finalized (only if Halt state is set - hybrid like) for cutting down times. Concept is the same as with network rendering.
As an example this is how can be done with Blender:
1. Set same scene as first file for rendering on CPU & another file for GPU. Use different seeds.
2. Run renderings (both at the same time).
3. Merge resulted images.
Will do a manual test later.
Thanks for giving an opportunity to be involved in the R&D process.
Learn something new every day.
PS.
What would also cut down rendering times significantly is denoising as Pixar, Cycles (LWR in development), Corona (in development, will be released in next version).
System
Win 7x64 pro
McLaren Optimized:
Bedroom:
PS.
Hey Prof4D,
Octane uses CUDA and not OpenCL for rendering.
No idea what your Octane screens should tell us...
Update your Drivers to the latest version (very, very, VERY important in OpenCL land)
latest are: GeForce 364.72 WHQL
Check your LOG in the Indigo GUI to see what error message Indigo gives ya.
