A natural situation
yonosoy
Re: A natural situation
Post by yonosoy » Fri Mar 04, 2016 11:08 pm
Yes contegufo, I know...
So, some things.
The second envelope for clouds by CTZn is great. The only thing is that runs slower.... and now I know why:
The value for max. coef. extinction is 0.05; I usually take 0.01. So this second envelope is faster than the first.
And the first time i use the multifractal function for the landscape.
Clouds volume is about 200x200x2 km. Godrays catched at last!
Post by Oscar J » Sat Mar 05, 2016 1:04 am
:O
yonosoy
Post by yonosoy » Sun Mar 06, 2016 2:17 pm
Testing the built-in multifractal function. Three basis type.
yonosoy
Post by yonosoy » Tue Mar 08, 2016 9:00 am
45h of render, is enough for me to see the beauty...
Instead of zoom-in and complain about the noise, zoom-out!
200x200x4 km of volume. Only a part of it. Of course exhaustive.
The beautiful interaction below the clouds (godrays).
Post by OnoSendai » Tue Mar 08, 2016 9:01 am
very pretty!
Polinalkrimizei
Post by Polinalkrimizei » Tue Mar 08, 2016 9:09 am
What an elaborate way to torture computing machines :)
yonosoy
Post by yonosoy » Tue Mar 08, 2016 9:12 am
hahahahahah....
I don´t need the machine for nothing more I believe.
Thanks Ono.
I´m "trying" to study beaux arts at this moments. I don´t consider myself like an artist. Time and we see... At the moment this is my only composition for art. Stranges disapointments between a net and a mesh. I re-exposed the same igi four times with different azimuth.
I expect to use the machine in a more creative way in the future.
kklors
Post by kklors » Tue Mar 08, 2016 11:11 am
yonosoy wrote:45h of render, is enough for me to see the beauty...
Wooh that looks fluffy <3
Post by CTZn » Fri Mar 25, 2016 9:02 am
Polinalkrimizei wrote:What an elaborate way to torture computing machines :)
and men :>
Pretty much on point yonosoy, nice clouds !
Post by CTZn » Fri Mar 25, 2016 9:04 am
yonosoy wrote:Testing the built-in multifractal function. Three basis type.
You are one click away from using textures for elevation control, keep it going !
Onizuka
Post by Onizuka » Thu May 05, 2016 11:30 am
Nice yonosoy
I have a question, are the god rays created automaticly after the light passes through the clouds ? Or is there a layer of "fog" under the clouds to catch the density of the rays ?
And by the way could you please tell me what is your computer configuration for your renders to be such clear in that time ?
Post by CTZn » Fri May 06, 2016 4:57 am
Onizuka wrote:I have a question, are the god rays created automaticly after the light passes through the clouds ? Or is there a layer of "fog" under the clouds to catch the density of the rays ?
God rays are a consequence of scattering, so yes they will appear (at a time cost) if a partially occluded, incoming light is passing through a scattering media. In the here case, disabling godrays would also disable clouds in one go, as they are from the same phenomenon (scattered light).
Onizuka
Post by Onizuka » Fri May 06, 2016 5:05 am
Ok thanks for the explanation CTZn,
Then I never rendered clouds long enough to see the god rays :lol:
Post by CTZn » Fri May 06, 2016 6:55 am
Well, the volume must extend below the clouds range so scattering can happen, ie the cloud box bottom must be dragged down to (or better, below) the floor with some non-zero sss value within.
Onizuka
Post by Onizuka » Fri May 06, 2016 11:40 am
Ah ok I see why there is still no god rays in that test I did before to see your new post ! I'm gonna test the same scene with the cloud box going under the ground.
