Oscar's rendering thread
Re: Oscar's rendering thread
Post by zeitmeister » Tue Mar 08, 2016 10:35 pm
Yeah!
Cheers, zeiti
Post by Oscar J » Wed Mar 09, 2016 1:23 am
Extremely simple. Smaller, colder and sharper key light, and bigger warmer fill light. White diffuse BG.
Post by Oscar J » Sun Mar 20, 2016 7:16 pm
A hood. Indigo 4 as per usual - it's truly killer for scenes like this.
Post by pixie » Mon Mar 21, 2016 3:05 am
Oscar J wrote:A hood. Indigo 4 as per usual - it's truly killer for scenes like this.
how does it compare with oldie indigo? I've seen some renders before and they didn't quite match.
Post by Oscar J » Mon Mar 21, 2016 4:27 am
Looks pretty much identical, unless you're using features that aren't implemented in GPU mode yet (although they are definitely getting fewer).
Post by Oscar J » Tue Mar 22, 2016 11:38 am
Done modelling!
Post by zeitmeister » Tue Mar 22, 2016 9:08 pm
Wow!
Post by Oscar J » Wed Mar 23, 2016 1:20 am
Thanks! :)
Will do a few more of these. This one is an 8 minute render - took about the same time to render out the Material ID pass. :)
Post by pixie » Wed Mar 23, 2016 3:06 am
Oscar J wrote:Thanks! :)
How much time would it take to render on CPU? Do you have an idea?
Post by Oscar J » Wed Mar 23, 2016 3:16 am
Would guess something like two hours or more. The Ms/sec number is about 8 - 10 times better in this type of scenes (the simpler the scene, the better the GPU mode seems to perform), but perhaps more importantly the convergence seems to better and you don't get the checkerboard patterns you sometimes see rendering with Indigo CPU.
contegufo
Post by contegufo » Wed Mar 23, 2016 6:25 am
Hi
Congratulations for the good work!
A question, Indigo 4 without using the GPU has the same performance of v3.8.30?
Post by Oscar J » Wed Mar 23, 2016 7:01 am
Thanks! Will wait for the admins to answer that I think.
More. :)
Post by OnoSendai » Wed Mar 23, 2016 7:05 am
contegufo wrote:Hi
Should be a bit faster.
Post by pixie » Wed Mar 23, 2016 7:20 am
Oscar J wrote:Thanks! Will wait for the admins to answer that I think.
More. :)
Wow! clean as a baby bottom's!
bubs
Post by bubs » Thu Mar 24, 2016 11:34 pm
Damn! you'd slice yourself on the back of that bad boy! 8)
