Indigo crash on MacPro
SreckoM
Post by SreckoM » Tue Jan 19, 2016 2:01 am
I am having constant crash with Indigo app on MacPro. This is customised MacPro with GTX770 and Nvidia web drivers. Might that be cause of crash? Every other app, much more complex than Indigo are working perfectly.
This is the error I get:
Indigo Renderer quit unexpectedly while using the QtOpenGL plug-in.
My workaround is to turn off OpenGL window, which I am not using anyway. So does anyone else have same problems?
Re: Indigo crash on MacPro
Post by Zom-B » Tue Jan 19, 2016 2:33 am
You named the problem: "QtOpenGL plug-in" and you named the solution for it: "turning off the OpenGL preview" 8)
There is the good chance that the OpenGL preview causes some heavy RAM usage on your GPU, if you start Indigo from a 3D app, this adds to the RAM usage you already have for that scene loaded in this 3D app...
SreckoM
Post by SreckoM » Tue Jan 19, 2016 2:41 am
I do not think it is RAM. I have 4 GB on this card, plus this happens even if I hit New Material and start tweaking something.
But yeah OpenGL is turned off so I can live without it. Just wanted to report this.
Post by lycium » Tue Jan 19, 2016 4:22 am
Thanks for reporting; the Indigo GL view doesn't actually limit the amount of memory it uses, which can conflict with GPU rendering memory usage I guess.
With Indigo 4's fast GPU rendering we'll probably leave it behind, however.
contegufo
Post by contegufo » Tue Jan 19, 2016 4:35 am
Hi
I too had the same problem when I access the disk (save image, load environment map).
I installed El Capitan and the problem not been replicated even with the window open OpenGL.
Post by Oscar J » Tue Jan 19, 2016 4:57 am
^ Yes, I used to have that problem as well, but not anymore. I think it might be due to upgrading to El Capitan as well. Maybe there was a graphics driver bug in the earlier Mac OS versions?
SreckoM
Post by SreckoM » Tue Jan 19, 2016 5:24 am
I have El Capitan too, must be issue with Nvidia web drivers that I am using instead of Apple drivers.
contegufo
Post by contegufo » Tue Jan 19, 2016 5:26 am
try deleting the preferences QuickTime?
Post by Headroom » Tue Jan 19, 2016 12:44 pm
Apple's implementation of Open GL is notably not the best. I guess there's a reason they have implemented Metal, their new Graphics and if I understand it correctly also GPGPU API.
SreckoM
Post by SreckoM » Tue Jan 19, 2016 10:25 pm
Yeah probably that, or maybe some bug with Qt which is used to build UI, I think ... I am having QT crashes even OpenGL window closed.
Post by OnoSendai » Tue Jan 19, 2016 10:29 pm
Hi SreckoM,
Can you try using the normal Mac graphics drivers and see if that makes a difference?
SreckoM
Post by SreckoM » Wed Jan 20, 2016 2:07 am
Unfortunately that brings more problems. Can not open Indigo than, because of some CUDA error, probably as drivers are messed after change.. Might be because of my system as it is highly customised, more hackintosh than MacPro....
contegufo
Post by contegufo » Wed Jan 20, 2016 6:59 am
You have an AppleMac or a PcMac?
Originalplan®
Post by Originalplan® » Thu Jan 28, 2016 5:14 am
Hey Guys.
Same(ish) problem here...since yesterday.
Indigo App crashes everytime i try to load a texture into the color chanel of a material.
Plus it crashes everytime i drop an .igi file into the App....strangely not when im opening it from the file menu.
OSX didnt show any specific problems just crashes.
Im on a Mac Pro 6.1.
Originalplan®
Post by Originalplan® » Thu Jan 28, 2016 5:23 am
(UPDATE) I think it has something to do with Crazy Bump app....(on my end) when i load a texture not made in crazy bump app...it works fine. Strange.
