by suvakas » Wed Mar 07, 2007 3:26 am
Here you go...
Suvakas
- Maxigo-07_v01b.zip
- (134 KiB) Downloaded 217 times
Xman
by Xman » Wed Mar 07, 2007 3:31 am
suvakas,
Thank very much
Xman
by Xman » Wed Mar 07, 2007 4:25 am
hi suvakas,
bidirectional no work?
- 00.jpg (55.33 KiB) Viewed 3203 times
Kosmokrator
by Kosmokrator » Wed Mar 07, 2007 6:03 am
no work for 0.7 tes 5 xman.........
dont try to enable it......
Xman
by Xman » Wed Mar 07, 2007 6:51 am
maybe,Nick at fixing BID again.
by Kram1032 » Wed Mar 07, 2007 7:13 am
He's working on BiDir, atm
Kosmokrator
by Kosmokrator » Wed Mar 07, 2007 7:51 am
hey but what exactly does the bidir?know someone?i dont have understand yet......
btw i think is good .....
by suvakas » Wed Mar 07, 2007 7:58 am
by Kram1032 » Wed Mar 07, 2007 8:00 am
I think, it helps letting caustics appear earlier, correcter and nicer...
It may also help SSS, but that's the problem with it: the actual Code doesn't work with SSS...
For 100% correct info, you have to ask Ono...
Kosmokrator
by Kosmokrator » Wed Mar 07, 2007 8:10 am
xxmmmm
F=Σ Σ ω st(x,st)fi(xs,t)/ps,t(xs,t) * (Ono=god)
yes of cource now i understand.......
i nevere be good in mathematics (espesialy in this math)
ok i have read the text at least and i understand some things!
thnx f help...
by Kram1032 » Wed Mar 07, 2007 8:16 am
I'd understand it, I think, if anyone would explain me, what which variable does:
I'm not that bad neither in maths nor in physics, I just need a BIT, a very tiny bit, of explanation...
Kosmokrator
by Kosmokrator » Wed Mar 07, 2007 8:53 am
ok kram lets say someone u explain each variable of this equations is......u can make an unbiased rederer?No.....is far far away to implement an formula into algorithm...an working algorithm!
indigo=(ono+prog skills)mathematics
by Kram1032 » Wed Mar 07, 2007 8:58 am
That's not, what I meant, sorry
I meant, if someone explains me every single variable, I'll get the meaning of this formula.
But I can't do one single line of C++
I can't even do html quite good, for now!
So I wont be able to even do something far from this!
Kosmokrator
by Kosmokrator » Wed Mar 07, 2007 9:03 am
suvakas are u there?here?somewere? any new update of little fixes and improovments?
by suvakas » Wed Mar 07, 2007 9:05 am
Yep, im here
..and working on the exporter. Doing some tricky stuff. I hope i won't break any working code...
Suvakas
