I like tricks. My experience is that in professional CGI production, you always end up using cheats and tricks anyway, so you might as well let Indigo do it for you.
- thesquirell
True that!
Exactly. The idea is to save the end user from having to shop in some clouds, or to prevent the end user having to use an env map. (that will probably result in an incorrect look due to non-physical values in the env map)Oscar J wrote:I like tricks. My experience is that in professional CGI production, you always end up using cheats and tricks anyway, so you might as well let Indigo do it for you.
real flow + cinema 4d + indigo simple test
Nice, though the fluid looks a bit low-res for some reason. Keep tweaking
Perhaps not so simple but i wanted to share
Probably one of the most ambitious things ive done with indigo in awhile. Modelling took quite awhile and then the rendering took a few days of tweaking xD Some post pro done in ps cc
Do you like sweet whimsical?
late answer...
Ono's trick is doing fantastic, and this quickly.
absolutely true I'm a playful idealist that's allthesquirell wrote:In general, I dislike tricks in CG, but sometimes we are forced to use them. Dreaming of day when we will have powerful machine that enables us to do whatever we want, and simulate everything in RT!
I used
Enviroment>Sun and Sky (turbidity 2)
Bidrectional with MLT
Focus point aperture f1.4 Aperture Diffraction
Any sugestions? Thnx
Skindigo
Render time 15min (Samples per pixel 200 ) it's just test render whit a little of photoshop
Skindigo
Everything looks shiny, even the sectioned walls: I suggest you check you mats and set the white walls as diffuse and paint the back face with a flat black. This way, you'll enhance the perception of the inner architecture, which I think is the aim of the work.
IMHO work a little in postpro on the contrast to give more overall depth!
Try to tweak the colour balance until you get rid of that sterile, blueish tint of your whites. Will look ten times better.
Users browsing this forum: No registered users and 164 guests
