Atmopheric scattering in blender
Blender 2.70
Blendigo 3.6.17.0
Indigo 3.6.18
Can anybody out there gives me a hint on how to produce a scene in Blender with Atmospheric Scattering? I have searched everywhere within past posts and the manual and can't find anything.
Even searched on that error message (the one at the bottom) on the World Wide Internet.
I mean, what I am trying to do is pretty simple...
- A scene with a box in the middle,
- A sphere all around my scene (BIG sphere)
- A specular material on the BIG sphere with Atmosphere as the medium type
That's it and I am always getting the following error message :
"Scene parsing error: could not find element 'center'. (In element 'atmosphere', around line ..."
What, where, when, why the heck do I get that center element in the scene from Blender.... It's been driving me nuts for the past couple of weeks...
Thanks in advance,
Blendigo 3.6.17.0
Indigo 3.6.18
Thanks in advance,
Re: Atmopheric scattering in blender
Hi.
The way atm is to assign an atmosphere material externally.
Atmosphere need a center of reference that is not implemented in blendigo.
Also there is a lack of understanding in GUI since a real one need a value of 7 digits and only accept 6.
The sphere needs a radius of 6458135 m. and to be placed in 0,0,-6378135 m. (perfect sphere).
Then your scene needs to start at 0 m. Hope is all.
Thanks in advance.
EDIT: also extra-atmospheric sun and Path Tracing Simple is required.
EDIT 2: in GUI, the center accepts the min value of -1000000 (7 digits, but needs -6458135. (there are other ways: to center the universe in the center of the Earth (value of atmospheric center 0,0,0))...
Thanks in advance.
<atmosphere>
<center>0 0 -6378135</center>
<turbidity>2</turbidity>
</atmosphere>
In the GUI, setup a specular material with the atmosphere medium applied. Save it in the HDD.
Open it with a text editor and in the section <atmosphere> change the <center>... line as shown above.
In blender, put a sphere of 6458135 meters of scale in the point z=-6378135 and assign to it a external material (the first of the list). Link the atmosphere material saved in the HDD and give to it the same name that the material has (it is shown near the box of name).
The scene starts at 0 m of heigth (universal center).
If helps it is possible to reproduce Ono's atmospheric example inside blender with the material linked, just say it.
Thanks, bye.
</atmosphere>
Thanks, bye.
Ok, I got something... Not sure what but I think I am going somewhere... I'll have to play with it a little bit more...
Thanks Yonosoy... your post helped me getting started...
Perhaps it could be an environment option, so that the atmosphere sphere is automatically created for you? It would be great to be able to define a custom radius as well, for atmospheres (planets) of different size...
Hi.
The atmosphere medium is the Earth atmosphere.
Only works in this range 6378135-6458135 (80 km.).
The feeling is that this center is there for "to do the trick": (to use a little box over the scene instead of the complete atmosphere sphere)...
An environment option that consider the placement and dimension of the atmosphere is a nice option.
For other planets ... custom atmospheres (so hard...).
The beautiful part is to define the custom atmospere with the meaning of "density" (less concentration in altitude), No idea ...
EDITED with the right range values...
Fully agree witty Tom, if atmosphere should be useable for normal users. Manually creating those spheres, well...
- zurkdahool
Thanks to the advise from yonosoy in the de-couple thread i stumble over to this thread. The explanation from yonosoy is very good. Because i am working on the medium stuff in blendigo i will see what i can do with the atmosphere. It should definitely be an easy 'enable atmosphere' button exists...
- zurkdahool
amazing ... i understand the atmosphere feature
thanks to yonosoy! i have tested it to setup manually in blendigo without any external editing (textfiles...) and it looks good to me:
'Automatic atmosphere setup' in blendigo is possible. Have to think about the implementation...
Awesome.
- zurkdahool
Atmosphere is now out of medium panel and moved to world panel as 'atmosphere feature':zurkdahool wrote: 'Automatic atmosphere setup' in blendigo is possible. Have to think about the implementation...
How it works:
Enable atmosphere will add empty sphere (Indigo Atmosphere). This is just for imagination... When exporting the scene to indigo the sphere, specular material and atmosphere medium will added automatically. After export the sphere will be deletet (not implemented yet as you can see in the screenshot
Very nice! Like the option of being able to relocate it in the Advanced tab.
Is this in the git repo? Should I be keeping up to date with that?
Tom, have a look in his post here (scroll down):http://www.indigorenderer.com/forum/vie ... 2&start=45
So yes, looks like there might be some great stuff added there in a while.
