contegufo
by contegufo » Tue Aug 11, 2015 9:00 am
Hi, a question,
1) In SketchUp and Blender you can launch simultaneous rendering (4,5,6,7) with the only limit of the available RAM.
2) In Cinema 4D it is possible to "render to picture viewer" and "Indigo plugins for Cinema". So only two that you can go a simultaneous rendering? It's possible?
Thank
by Zom-B » Tue Aug 11, 2015 6:43 pm
You can render to externally installed Indigo as often as you like and start as many instances of Indigo as you wish out of C4D or by hand!
Only take care not to enable network rendering by more then one of these
contegufo
by contegufo » Tue Aug 11, 2015 11:55 pm
I'm sorry but I did not understand.
Could you tell me in detail how to do it?
Thank you
by Zom-B » Wed Aug 12, 2015 12:33 am
click 10 times render in indigo to spam 10 renderings!
contegufo
by contegufo » Wed Aug 12, 2015 3:47 am
Hi
I state my configuration:
MacMinis (2011), 8Giga Ram, Yosemite 10.10.4.
I think the problem is in Cinema and precisely in Cindigo version.
I Indigo 3.8.26 which works very well with Blender SketcthUp and could leave many simultaneous rendering. In Cinema it will only work the first time; subsequent add nothing to the first. Basically the software indigo can launch once. Why?
- It is not possible with Cinema.
- The window will remain the same despite launches Indigo 2,3,4,5 times.
by Zom-B » Wed Aug 12, 2015 4:05 am
Ah OK, on a mac everything can be different, I'm on a PC
Here some dev or other mac people could maybe help...
First I suggest you make sure to use the latest Indigo Exporter v 3.8.26.2 for C4D:
http://www.indigorenderer.com/forum/vie ... 10&t=13576
as workaround you could export your scenes to
different defined names & folder,
then simply open Indigo by hand, and load the exported igs files directly instead using.
Since you only exporting to "quickrender default" in your example, maybe this is the issue...
by Oscar J » Wed Aug 12, 2015 4:09 am
Blendigo opens multiple instances of Indigo on my Mac. Weird that C4D in particular behaves differently.
contegufo
by contegufo » Wed Aug 12, 2015 5:35 am
Hi
I tried Cindigo R12 and RT14 (Cinema 13, 14, 15) but nothing changes and I also in the "render to picture viewer" watermarks !!!! In Blender and in SketchUp can have many simultaneous rendering in Cinema but at most two .....
Thank
thesquirell
by thesquirell » Wed Aug 12, 2015 7:48 am
Just to add that with C4DR16 and newest Cindigo, as well as with the versions before I didn't have any problem of these types. I could, and still can render as many scenes I want, really don't know the problem, apart from that custom export paths.
contegufo
by contegufo » Wed Aug 12, 2015 10:33 am
C4DR16 use with Mac?
thesquirell
by thesquirell » Wed Aug 12, 2015 12:37 pm
No, sorry, I am a Win user.
contegufo
by contegufo » Wed Aug 12, 2015 7:21 pm
Hi
I think Mac C4D can not launch more than one instance.
A escamaotage may have another version of C4D and another version of Indigo es. (C4DR13 + Indigo 3.8.25), it is possible with SketchUp and Blender.
Thank
by Oscar J » Wed Aug 12, 2015 7:31 pm
Since it's possible with blender and sketchup under OS X, it probably shouldn't be too hard for the devs to fix.
contegufo
by contegufo » Thu Aug 13, 2015 5:07 am
I think developers should inform users.
by Zom-B » Thu Aug 13, 2015 5:14 am
Afaik fused the developer of that exporter is on vacations atm -.-'
He'll return back for sure once he's back.
