Indigo Exporter for 0.7t5 - beta release
hi Xman,
copy "res and cinema4dsdk" to "CINEMA 4D R10/plugins/Indigo Exporter 0.7.5" would be better.
but there seems to be a bug in my res files anyway. will check that.
where are you from?
edit: yes it was a bug (forgot a ";"). wonder why R9 didnt complain
where are you from?
ok, next release will have a version number
sry for confusing you
me loves the word "confused" (especially the last part
edit: uploaded a new version WITH version number (0.2, everything before was 0.1) and Xmans bug fixed.
INDIGO EXPORTER FOR C4D v0.2
download exporter
please tell me if you find bugs(bugs i dont know about, that is
) or have specific requests. i will try to fix/implement as fast as possible.
known bugs/issues v0.2:
*MESHLIGHTS DONT WORK (they do but not as they should)
*objects grouped with null-objects wont be exportet, will fix that soon
*base objects (e.g. plane,sphere) are not supportet yet
*sometimes you have to guess the right fields, didnt find out how to hide them yet
*env maps are not supported yet
*textures are not supported yet
*no epidermis and demis for now
*and probably much more...
FIXED-list v0.2:
* FIXED: overrides
* FIXED: no glossy transparent
* FIXED(peak not supported yet): only blackbody for meshlights
* FIXED(.3ds and .obj supported now): only .3ds supported for now
* FIXED(well not really
): you have to export your camera vectors by hand
* FIXED(i can render scenes exported with my exporter
):export itself is VERY buggy
* FIXED: Exports single objects now
list is getting shorter
download exporter
FIXED-list v0.2:
* FIXED: overrides
Exporter doesn't work for me..
Hello, i attached a scene file which i want to export, but my cinema still freeze during exporting...if i delete object tags, scene will export but without 3ds objects...could you help me friends???
My software version C4D 9.6, windows xp 64 bit.
Greets for you from Poland:)
Hris
Hris
- Indigo_test.zip
- This scene is wrong for exporter, but why?
- (9.28 KiB) Downloaded 377 times
hi hris, applying only the material helper is not enough.
you must also apply the cinema 4d material to the object.
the material helper is only to set up the indigo materials and needs to be appied only once for every material you use.
and please try to avoid material names with a ".", they get exported wrong (cinema issue, not my fault)
pinko, ill have a look at it. ill see what i can do (at the moment i have no clue)
a little meshlight test:
and a new release!
INDIGO EXPORTER FOR C4D 0.2.1b
download exporter here (or below)
the file contains "sampleScene.c4d" for everyone who still doesnt know how to setup stuff.
new in 0.2.1b:
* NK supported (i think - not tested)
* demis and epidermis supported
* planes(only normal = (0 0 1) for now) and spheres supported
* formated the mat helper tag for better understanding
* henyey greenstein supported now
* code was getting pretty confusing, so i made it at least a bit object orientated, much easier to understand now... thats not for you but it took some time so i at least wanted to mention it
known bugs/issues 0.2.1b:
* objects grouped with null-objects wont be exported, will fix that sooner or later
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* env maps are not supported yet
* textures are not supported yet
* camera (you can use the settings contained in "standart camera.txt" or export it with BL exporter, im working on it)
FIXED-list 0.2.1b:
* FIXED: fixed meshlight (only .3ds export for now, normal smoothing false by default)
* FIXED: mesh position and (hopefully) rotation
this is the first useful release i think
and a new release!
new in 0.2.1b:
FIXED-list 0.2.1b:
- Indigo Exporter 0.2.1b.zip
- Indigo Exporter for Cinema4D 0.2.1b
includes sample .c4d file - (329 KiB) Downloaded 335 times
