So, I'm running in to what appears to be a bug... for some reason, if I'm working in a document for long enough, the "Edit Active Mesh" dialogue option no longer produces the "Edit Active Mesh" pop-up window. I see it listed, click the option, but nothing happens. I get the same result no matter which object I select in my document.
However, if I create a NEW document, the "Edit Active Mesh" dialogue suddenly works again and pops up the appropriate window. But, sadly, when I try the same thing in my original sketchup file, it still does not work. My only recourse is to select everything in my file, and then copy and paste in to a NEW file, where once again the "edit active mesh" dialogue functions properly. But this "solution" is obviously less than ideal, since I lose my layers, matched photos, etc, that do not carry over from a simple copy/paste.
Has anyone else run in to this issue? Is there a solution?
My specs:
Macbook Pro, OSX 10.9.5
Sketchup Pro 8
Indigo 3.6.26
Skindigo 3.6.28.4
'Edit Active Mesh' stops working (nothing pops up)
chrisbwallace
Re: 'Edit Active Mesh' stops working (nothing pops up)
'Edit Active Mesh' works after delete all?
you can try 'Save a Copy As'...
Is possible to share skp file for you?
