Help needed : Indigo not responding (Skindigo RT)
- Alejandro_66
Hello everyone,
I have a problem with Indigo freezing an "not responding" message each and every time i try to, either save image or IGI file... Render for 10 minutes or 10 hours with same result... Very frustrating at this point...
Any help welcomed. Thank you.
Alejandro
Alejandro
Re: Help needed : Indigo not responding (Skindigo RT)
What resolution are you rendering in?
- Alejandro_66
Oscar i was rendering in 2800x2000.Oscar J wrote:What resolution are you rendering in?
Check RAM usage during the rendering/saving.
If you start a rendering, in the displayed log there is a line named "Master buffer size:" how big is that for your scene?
And last but not least: has the HDD you save your stuff on enough free space??!
- Alejandro_66
Hello Zom-B,Zom-B wrote:Check RAM usage during the rendering/saving.
Yes I have sufficient space. I start the render and everything is fine up until I try to save image...
Left a render to work through the night, came back this morning and still same problem...
Here's a screen capture with Render log.
Thank you very much for taking the time to help me solve this problem.
Kind regards,
Alejandro
Have you tried reinstalling Indigo?
- Alejandro_66
I think i have no choice at this point. I will let you know if it solves the problem.Oscar J wrote:Have you tried reinstalling Indigo?
Thank you.
Alejandro
Don't use GPU rendering, that should fix your issue!
- Alejandro_66
Hello Zom-B, So far that seems to work! Thank you!Zom-B wrote:Don't use GPU rendering, that should fix your issue!
