kklors render stuff
Re: kklors render stuff
wow, very outer space, Hubble type of image
can you reproduce it?
Hi perfahl, you can download it from the most recents posts in my own wip thread right into this very sub forum.CTZn wrote:perfahl wrote:really nice renderings! where can we try the clouds shader? could not find it in the materials section..
I have not uploaded it because it is experimental.
Thanks CTZn!
Juju wrote:wow, very outer space, Hubble type of image
Thank you!
Yeah i can, although it changes appearance quite drastically because it's all micro scale.
More shader tests. Remotely based on the cloud shader, until things went out of control.
are the staired lines shader based or mesh ? if the former how the heck !?
It's sort of both. The stairs come from a mesh, a shader drives opacity and position.CTZn wrote:are the staired lines shader based or mesh ? if the former how the heck !?
More stuff...
- thesquirell
That,that,that...cloud over there on the second image...is that CTZn cloud?! O.M.G....
even though they might originate from my shader, I believe that kklors is able and encouraged into derivating from them !thesquirell wrote:That,that,that...cloud over there on the second image...is that CTZn cloud?! O.M.G....
Haha it is. Frankensteined a lot though. Not that I know what I'm doing to be honest. That stuff works for certain scenes and certain light angles sometimes, sometimes it doesn't.thesquirell wrote:That,that,that...cloud over there on the second image...is that CTZn cloud?! O.M.G....
A quick something while nerding GDC.
Your "stuff" blows my mind. In a good way
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Man, the shader in that last one is incredible! Can you share any details of setup?
ahwmazing, I would like to know more...kklors wrote:Untitled
Does look a bit like pencil in a way.
Thanks a lot!
Unfortunately it's not a shader. As stupid simple as it sounds pretty much all what makes this effect is MLT noise and brutal overexposure. I attached the original render.
The only thing I did to it is slightly blurring it and applying some swirly fractal noise ontop in Multiply at 15% opacity. That's it. Loved the hatched sketch look in the raw render already, just tried to emphasize it.
Users browsing this forum: No registered users and 157 guests
