Post by neo0. » Wed Feb 04, 2015 7:25 am
Nice!
Silmä
Post by Silmä » Thu Feb 05, 2015 5:41 am
I bought a new monitor, so I had to re-render one of my old scenes in larger resolution to get new desktop wallpaper. Also played around some with the light layers to get some more color in it.
It's a part of a visualization I made for a concept for a parametric design course I had a couple of years ago. The real thing ended up being a lot more sturdy, and it was a pain to build. You know, as a kid you wish you had a million legos so you could build a fortress, but when you actually have to stick them together (or even some 10 000 of them) you quickly forget that dream...
lape
Post by lape » Fri Feb 06, 2015 9:17 am
some bubbles
24 hours isn't enough
http://www.werkraum3d.com
bubs
Post by bubs » Fri Feb 06, 2015 10:41 pm
nice! 8)
DJ AntOn
Glass
Post by DJ AntOn » Sat Feb 07, 2015 1:24 am
простой стакан с яблочным соком
simple glass with apple juice
Re: Glass
Post by CTZn » Sat Feb 07, 2015 7:27 am
DJ AntOn wrote:простой стакан с яблочным соком
the mesh is low resolution, its normals should be set to hard, not smooth. this is biasing the render geometrically speaking.
you can use Indigo subdivisions to smooth the geometry. Sorry I can not read russian !
Tramis
Post by Tramis » Tue Feb 10, 2015 6:33 am
Hello all!
First of all, I'd like to say I an a new user of Indigo renderer. And I LIKE IT! :)
This is my first water drop test. It doesn't look real enough to me. Maybe you have some suggestions.
C & C's are always welcome. :)
Btw I'm using Firepro V4900 GPU. I know it's not meant for rendering. Maybe you could suggest which GPU to buy? AMD of Nvidia? AMD -> OpenCL, Nvidia -> Cuda?
Thanks! :)
Software: Cinema 4D, Indigo renderer.
Post by zeitmeister » Tue Feb 10, 2015 7:04 am
Try bidir MLT for nice caustics, and add something to the cauchy_b-value in your water material.
Welcome to indigo!
Cheers, zeiti
Tramis
Post by Tramis » Tue Feb 10, 2015 8:33 am
thanks David,
I put the value of 0,01000
the result
Post by CTZn » Tue Feb 10, 2015 8:54 am
Tramis wrote:This is my first water drop test. It doesn't look real enough to me.
realism will depend on a number of parameters, and when it comes to such a simple subject the most important is how light is interacting with the environment.
try adding objects that will interfer with the drop's lighting, and welcome BTW.
Post by pixie » Tue Feb 10, 2015 9:25 am
Tramis wrote:thanks David,
the result
You also need a small size emitter.
Tramis
Post by Tramis » Tue Feb 10, 2015 10:17 am
I used HDRI environment as a light source. What kind of emitter you are talking about? Plane or simple light? I'm new to this. :)
Thank you for suggestions
Post by Oscar J » Tue Feb 10, 2015 12:09 pm
A small emitting plane would do the trick. I think the water drop looks quite realistic already though, try making the ground material wood or something.
Post by pixie » Wed Feb 11, 2015 1:21 am
Tramis wrote:I used HDRI environment as a light source. What kind of emitter you are talking about? Plane or simple light? I'm new to this. :)
A light is basically a plane with a light emmiter material. :) Add one, set the size, give it a different layer and off to the moon! :D
Post by Headroom » Thu Feb 12, 2015 1:49 pm
If you want more caustics, which really is what makes renders like this more interesting then use multiple small but bright light sources.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Users browsing this forum: No registered users and 107 guests
