Scatter editor test: Forest
- Antonis777
Re: Scatter editor test: Forest
Wow! You attention to detail is really paying off here. Would love to see this in higher resolution.
- Antonis777
Thanks guys! l hope also to see it in higher resolution, but I have demo version.!
That is amazing, congrats Antonis!
Is the sun flare added in post-production?
- Antonis777
No it's aperture diffraction effect in which I used two pictures, one as aperture and one for obstacle map. The only thing I did in post pro is a little increase with lens flare effect of Photoshop at 30%. Here's the raw render.
Even more amazing
Great test and render!
- Antonis777
Thanks a lot..!
Wow, nice glare! I was so sure it was post-prod. You should do more of this nature stuff!
Oh, and the devs are usually helpful if you want something rendered clean and high-res. This render sure deserves it.
- Antonis777
Thank you again for your comments! I' ll put the scene if anyone cares to use it..! And one last thing. I noticed that if your camera faces directly the sun, the level of brightness decreases a lot. For example I put reinhard prescale at about 30. Don't know if this is a feature of Indigo, or a bug. here are the examples.Oscar J wrote:Wow, nice glare! I was so sure it was post-prod. You should do more of this nature stuff! :D
- Antonis777
Is there a mb upload limit? I am trying to upload my scene in skp 14 mb and zip 9.6 mb format and nothing happens...
..never fiddled around with the Reinhard settings: I always found them not so user friendly compared to the standard camera settings. You should try! So many things will come to be more clear you'll see
- Antonis777
I agree with that, but the same thing happens with camera settings also..!
FakeShamus
That darkening shouldn't happen with camera or linear tonemapping.
because the Reinhard tonemappng will adapt the exposure in order to receive a constant energy, sort of. Other types have a more controllable output indeed.
