SkIndigo 3.8.18 (beta)
15 posts • Page 1 of 1
Post by OnoSendai » Sun Nov 23, 2014 5:12 am
Changelog:
Removed transmittance setting for Simple Thin material, using albedo colour for it instead.
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 3.8.18.rbz
Windows Installer:
Re: SkIndigo 3.8.18 (beta)
Post by Pibuz » Sun Dec 07, 2014 4:10 am
Hi Ono, I'm testing the 3.8 stable version.
I think something may be optimized when working with external-referenced objects: first of all the material handling! At the moment, Indigo tells us the name(s) of the missing materials (..only the first time, moreover..): could it be possible to automatically add SU materials named as in the mtl file?
At the moment the obj handling is a little bit confusing.
I can explain further if I wasn't able to make my point.. :mrgreen:
Post by OnoSendai » Wed Dec 10, 2014 7:05 am
Hi Pibuz,
Good idea, thanks for the suggestion.
Materials are auto-added now.
Some basic material conversion is done as well, including setting the colour and texture maps if present.
This is an external obj without any tweaking:
Post by Pibuz » Wed Dec 10, 2014 7:18 am
WoW excellent! Can't wait to test it!
..maybe add simple diffuse materials instead of phong?
Post by OnoSendai » Wed Dec 10, 2014 7:28 am
Pibuz wrote: ..maybe add simple diffuse materials instead of phong?
No thanks :)
At some point I'll add a SkIndigo option to make diffuse the default though, just for you :)
Post by Oscar J » Wed Dec 10, 2014 7:41 am
I hope you're not bringing phong as the default material to blender too. :shock:
Post by Pibuz » Wed Dec 10, 2014 7:54 am
No thanks :)
AHAHAHAHAHAH :lol: Thanks master :mrgreen:
Jeff Hammond
Post by Jeff Hammond » Sat Dec 13, 2014 12:35 pm
hi
i'm having a problem with my default settings sticking across sessions (as in, my default settings aren't remembered when relaunching sketchup)
for instance, my environment is set to Environment Map and i'd like to change it to Sun and Sky.
so i click the radio button next to sun&sky, press the Apply button, then also press Save Defaults.. at which point i get the popup "Current render settings successfully saved as defaults."
if i quit sketchup then relaunch, the setting is back to emap again.
osx 10.10 skindigo 3.8.18 suPro2015
(i'll be updated to 10.10.1 in a little bit but i doubt that's the fix.. i'll try it again anyway upon updating.)
pre-thanks for any help
Post by Pibuz » Sun Dec 14, 2014 9:19 pm
Hi Jeff.
To have a default indigo setting I've changed the parameters within the SketchUp template file.
Jeff Hammond
Post by Jeff Hammond » Mon Dec 15, 2014 7:25 am
Pibuz wrote:Hi Jeff.
cool. I'll try that out in a bit
tornello
Post by tornello » Tue Dec 16, 2014 2:03 am
Hi: why are now all materials default PHONG? :shock:
i think it should be correct diffuse; now everything reflects light. Is there a solution?
No thanks :)
Post by Zom-B » Tue Dec 16, 2014 3:12 am
tornello wrote:Hi: why are now all materials default PHONG? :shock:
No thanks :)
You quoted the reply to your answer by yourself tornello :lol:
tornello
Post by tornello » Tue Dec 16, 2014 3:14 am
Ok,
but WHY?
Why does the the new skIndigo version has set by default phong for all materials.
I think that in a render diffuse material has more sense.
1) Now when I open old scenes everything reflects :shock:
2) Now when I download an object from Warehouse every components (and there are many components in an object) reflects :shock:
Nonsense :(
Post by Zom-B » Tue Dec 16, 2014 3:21 am
tornello wrote:Ok,
but WHY?
Because if you look around you, you'll notice that the most materials are reflective!
Maybe not much, but the aren't absolutely diffuse, its more realistic, THEREFOR! :wink:
tornello
Post by tornello » Tue Dec 16, 2014 3:24 am
mmmmm :?
yes, but I am not so sure about the natural result.
I have rendered the same scene and it was all reflective
Zom-B wrote:
tornello wrote:Ok,
but WHY?
Maybe not much, but the aren't absolutely diffuse, THEREFOR! :wink:
Users browsing this forum: Majestic-12 [Bot] and 91 guests
