Skewed Texture Maps
9 posts • Page 1 of 1
bubs
Skewed Texture Maps
Post by bubs » Fri Nov 28, 2014 10:03 pm
Surprisingly I've obviously never tried this before with Indigo, but I recently used a texture map skewed to fit a surface, using SU non-fixed pins. The texture looks absolutely fine in SU but when I render in Indigo, the material is distorted.
Is this function simply not supported, or is this a bug?
Re: Skewed Texture Maps
Post by Oscar J » Fri Nov 28, 2014 10:34 pm
Don't use sketchup obviously, but in Blender that problem can be solved by subdividing the mesh.
galinette
Post by galinette » Fri Nov 28, 2014 10:38 pm
That's because Indigo does not support homogeneous UVW mapping which SketchUp uses. UV mapping is not able of skewing.
Subdividing makes the effect unnoticeable with enough subdivisions
Eclat-Digital Research
http://www.eclat-digital.com
Post by pixie » Fri Nov 28, 2014 10:49 pm
galinette wrote:That's because Indigo does not support homogeneous UVW mapping which SketchUp uses. UV mapping is not able of skewing.
Is there anything that galinette doesn't know? :P
bubs
Post by bubs » Fri Nov 28, 2014 10:52 pm
Thanks guys! :D worked like a charm! 8)
pixie wrote:Is there anything that galinette doesn't know?
The evidence would suggest not! :lol:
Post by Pibuz » Sun Nov 30, 2014 3:18 am
Picking the occasion to suggest a little tut to create cool flames like bubs'
Would be very cool to have on the online tutorials section 8)
bubs
Post by bubs » Sun Nov 30, 2014 4:48 am
It's actually just an Indigo material I made Pibuz... I've always had issues with it tho...
However, I sent it to our glorious leader (Ono :wink: ) yesterday and he is having a look at it for me! If he gets the bugs out I'll upload it to the Mat DB
Post by Pibuz » Sun Nov 30, 2014 5:11 am
..ok!..would have been interesting on the didactic side to have sort of a worflow explained, I thought :D
Thanks a lot btw!
bubs
Post by bubs » Sun Nov 30, 2014 5:50 am
OK, I can do if it's more of a workflow thing... bear in mind tho, that without the use of emitting double sided thins in Skindigo, to make it look OK is always going to be a work-around with light sources hidden from the camera... and I know you don't like that sort of cheating :wink: :lol:
