sun and backround
Come here for help & support.
10 posts • Page 1 of 1
horpa
sun and backround
Post by horpa » Thu Sep 25, 2014 12:45 am
why sun does not shine when I put it into the scene /attachment/. It is possible that the sun was shining and it I also used image in the background?
Re: sun and backround
Post by Zom-B » Thu Sep 25, 2014 12:49 am
you have to check "extra Atmospheric" to get this setup work :)
horpa
Post by horpa » Thu Sep 25, 2014 1:24 am
Zom-B wrote:you have to check "extra Atmospheric" to get this setup work :)
with "extra Atmospheric" does not work .... :(
Post by Zom-B » Thu Sep 25, 2014 1:31 am
It should work!
Doublecheck that your sun is actually in "day time",
also change away from Reinhard to linear or camera tonemapping.
fastest way is simply to upload your scene here and let me check it :)
horpa
Post by horpa » Thu Sep 25, 2014 2:17 am
Zom-B wrote:It should work!
... thank you ...
test1.zip
(6.75 MiB) Downloaded 492 times
galinette
Post by galinette » Thu Sep 25, 2014 2:29 am
Maybe your envmap/background is much too bright compared to the sun, try decreasing the envmap multiplier
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by Zom-B » Thu Sep 25, 2014 2:29 am
You set your EnvMap Emitter to BlackBody.
BB is soooooo bright that brighter could not go ^^
Therefor your sun was "tonemapped down" and not visible anymore...
Try this settings for your EnvMap, Emission Scale turned off since it doesn't work for EnvMaps:
horpa
Post by horpa » Thu Sep 25, 2014 7:58 am
Zom-B wrote:You set your EnvMap Emitter to BlackBody.
Yes, now work ! . Thank you very much.
Post by Oscar J » Thu Sep 25, 2014 8:02 am
Cool! Did you do the lawn using shadow catcher?
horpa
Post by horpa » Thu Sep 25, 2014 8:16 am
Oscar J wrote:Cool! Did you do the lawn using shadow catcher?
grass is just a texture and little polygonal grass .
