Python 2 ISL
Python 2 ISL
There is small help to control parameters in cindigo isl.
go to user data of mat and you can to control additional options as Thickness and Drying Speed
Prototype based at CTZn's material - Liquid Coating
- Isl_Python.zip
- c4d scene - c4d r16.021
- (85.98 KiB) Downloaded 371 times
I'm sorry for my bad English
Re: Python 2 ISL
This is quite smart, animated ISL Shaders
First thing I thought of here is a water material for a pool using ISL Noise, that has some subtle movements...
Thanks a lot for sharing this!
- pixie
Re: Python 2 ISL
ISL is for sissies, I rather code straight in assembly!Ilay wrote:There is small help to control parameters in cindigo isl.
Re: Python 2 ISL
If somebody needs to understand how to work, look at:
- 1. Look at c4d manual and learn how easy to add expressions by right clicking at options - set driver and set driven. You got xpresso tag and can manipulate with anything to translate code to isl shader string pool. Or if you are familiar with xpresso and working with materials as node shell - you don't need it. Or you can use direct access to mat via python tag. Anything....
2. For replacing code read about formatting Strings:
Re: Python 2 ISL
Another way - python tag
based at http://www.indigorenderer.com/node/1945
fused, thank you, nice for waves
p.s. mat[c4d.INDIGO_MATERIAL_THICKNESS] - this part you don't need
Re: Python 2 ISL
I do not do it
fused and CTZn made, i only add control gui by simplest way
Re: Python 2 ISL
Ha ha, that was the magic I was referring tooIlay wrote:I do not do it![]()
Your approach opens a tighter integration of ISL into C4D!
- pixie
Re: Python 2 ISL
He opened the Pandora Box!Zom-B wrote:Ha ha, that was the magic I was referring tooIlay wrote:I do not do it![]()
Users browsing this forum: No registered users and 95 guests
