SkIndigo 3.8.6.1
Re: SkIndigo 3.8.6.1
Post by OnoSendai » Wed Aug 20, 2014 9:38 am
Updated build:
Added searching for textures in scene directory when external texture path is invalid.
bubs
Post by bubs » Wed Aug 20, 2014 8:16 pm
Thanks Ono!
bubs
Post by bubs » Wed Aug 20, 2014 8:55 pm
Getting this error now;
SkIndigo version: 3.8.6.1
SketchUp version: 8.0.11752
Ruby platform: i386-mswin32
Ruby version: 1.8.6
Error during processing: wrong number of arguments (2 for 3)
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:514:in `export_base_emission'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:514:in `write_mat'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:118:in `export_material'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:1756:in `export_environment'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/skindigo_core.rb:217:in `export'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/skindigo_core.rb:2568
Post by OnoSendai » Thu Aug 21, 2014 12:08 am
Updated build with fix.
bubs
Post by bubs » Thu Aug 21, 2014 1:09 am
When you export a material with an opacity set to less than 100 this used to export as a blend between diffuse transmitter & diffuse, this now seems to export as a blend between 2 diffuse transmitters.
Post by OnoSendai » Thu Aug 21, 2014 2:08 am
bubs wrote:When you export a material with an opacity set to less than 100 this used to export as a blend between diffuse transmitter & diffuse, this now seems to export as a blend between 2 diffuse transmitters.
bubs
Post by bubs » Thu Aug 21, 2014 11:47 pm
I don't think the 'LinkedIGM' is working with .igm files... only seems to work with .pigm files.
I'm getting an error about missing materials with .igm
Post by OnoSendai » Fri Aug 22, 2014 12:10 am
bubs wrote:I don't think the 'LinkedIGM' is working with .igm files... only seems to work with .pigm files.
Seems to work fine here. Can you send a scene (.skp + .igm) showing this problem?
bubs
Post by bubs » Fri Aug 22, 2014 12:58 am
sorry my mistake, it was a bad material... working fine
Antonis777
Re: SkIndigo 3.6.8.1
Post by Antonis777 » Wed Sep 03, 2014 9:45 pm
ak-sam wrote:My first attempt is attached to this post - densities are about 2000 and 4000 for the 2 types of grass.
I've added a curved surface instead of a flat one, and added two more types of scattered object (total is now 4).
I get this error:
An error occurred while SkIndigo was exporting the scene.
Please copy and paste the following details into an email to support@indigorenderer.com:
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Ruby version: 2.0.0
Error during processing: undefined local variable or method `object' for #<IndigoMeshBuilder:0xed54210>
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:885:in `get_dummy_defn'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:638:in `build_linearised_definition_info_for_instance'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:699:in `block in build_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `each'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `grep'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `build_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:668:in `get_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:747:in `process_component_instance'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:848:in `block in process_entity_list'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `each'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `grep'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `process_entity_list'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:868:in `process_entities'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:184:in `export'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:2533:in `block in <top (required)>'
-e:1:in `call'
Got the same message
Post by OnoSendai » Sat Sep 06, 2014 12:49 am
kreen
please help me guys
Post by kreen » Tue Sep 16, 2014 8:15 am
SkIndigo version: 3.6.28.3
SketchUp version: 8.0.3117
Error during processing: undefined method `downcase' for nil:NilClass
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1314:in `exported_texture_filename'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1027:in `export_texture'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:292:in `write_mat'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:90:in `export_material'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:968:in `export'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:967:in `each'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:967:in `export'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:3414
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1476:in `call'
Post by OnoSendai » Thu Sep 18, 2014 5:14 am
kreen: you are using an old SkIndigo version, please try the one from the first post of this thread.
