RhIndigo - Indigo for Rhinoceros 5.0 thread
Post by StompinTom » Tue Jul 15, 2014 7:21 am
Hello,
Since it's going reasonably well - at least for a noob attempt - thought I'd post about Rhino / Indigo progress here. It's written in C# using the RhinoCommon render API, so it basically appears as another rendering engine in the Render menu. So far it's very bare-bones: basic geometry export, no materials (default white material, basic sun/sky and uniform backgrounds, and uses the active viewport for rendering (including ortho views). Supports meshes and NURBS surfaces (trimmed surfaces, polysurfaces, primitives, extrusions, etc.).
Basic materials + Sun / Sky using Directional Light
To do (to begin with):
- expose render settings
- expose camera / tonemapping settings
- implement material editor
- tighten everything up, re-think about the overall structure as it's a bit hackish atm
- eventually take a look at Rhino C++ API and hopefully see how to integrate Indigo into the viewports / render frame-buffer
It's not worth posting it at the moment, since it's quite scrappy, but I will try to get a version up sometime in the near future.
Suggestions for a better name, wishlist, better workflows, etc. are welcome, though don't expect miracles. Also, tips and hints about C#, Rhino, or programming in general would be much appreciated.
T
Re: RhIndigo - Indigo for Rhinoceros 5.0 thread
Post by zeitmeister » Tue Jul 15, 2014 9:40 am
Very cool! Rhino Users and coders, Support this guy!!
Grüsse, zeiti
sunlooksgreen
Post by sunlooksgreen » Tue Jul 15, 2014 8:39 pm
hi there! this is great news!
when you talk about integrate Indigo into the viewports would that mean we could navigate somehow real-time into the rendered model? and see changes to the geometry immediately appear on the render?
regards
tom
Post by zeitmeister » Tue Jul 15, 2014 10:37 pm
I think so; sort of.
But maybe he meant for now direct viewport rendering?
Grüsse, zeiti
Post by StompinTom » Wed Jul 16, 2014 1:21 am
zeitmeister wrote:I think so; sort of.
Grüsse, zeiti
Both would be great, but for now I've got enough on my hands to get the basics up and running :) I got some examples / bit of direction about custom materials in Rhino, so I will try to take a stab at that soon.
Post by zeitmeister » Thu Jul 17, 2014 3:59 am
Sure... Glad that someone writes something! :-)
Grüsse, zeiti
Post by StompinTom » Tue Aug 26, 2014 9:52 am
Had a bit of time this weekend to push this a bit further...
Render settings and such presumably save with the 3DM file now, though testing is needed. Very basic control of resolution, tonemapping, render mode, etc.
No materials yet, been going through some documentation on adding custom materials and still getting my head around it.
If you don't add a directional light, it will render with basic white environment. So far no exposure control is in yet.
If your surfaces are coming out chunky, go to Mesh->Render Mesh Properties... and adjust the meshing parameters there.
Anyway, here it is for those who want to have a go. Be nice, don't expect wonders, but let me know what works and what doesn't.
To install: unzip, then either double-click on the .rhp file and Rhino will automatically install it, or boot Rhino, go to Options...->Plug-ins, click Install and find the .rhp file. It's an x64 build, so if it doesn't work for you I can do a x86 one as well.
RhIndigo.zip
64-bit build
(14.81 KiB) Downloaded 808 times
Post by CTZn » Wed Aug 27, 2014 10:02 am
cool Tom, keep it up ! Are you being in touch with the Rhino community as well to spread the word aroundv?
Post by StompinTom » Wed Aug 27, 2014 10:59 am
CTZn wrote:cool Tom, keep it up ! Are you being in touch with the Rhino community as well to spread the word aroundv?
Nah, still needs a bit of work before that :wink:
Post by StompinTom » Wed Sep 03, 2014 8:46 pm
Got basic material export working. Indigo diffuse and phong materials are now options in the material editor.
sunlooksgreen
Post by sunlooksgreen » Sun Sep 07, 2014 11:38 pm
that's great! can't wait to have a usuable bridge so I can start using indigo..
CHF
Post by CHF » Thu Sep 11, 2014 1:23 am
First of all, thanks for writing an exporter. Really appreciated.
I downloaded and installed the plugin. It just starts out fine, but indigo throws the following error:
Scene parsing error: Failed to parse Vec3 from '19,5111 -29,1895 19,4016'. (In element 'scene / camera'):
<camera>
<pos>19,5111 -29,1895 19,4016</pos>
<up>-0,2691 0,4051 0,8738</up>
<... (In element 'scene / camera'):
<camera>
No Metadata.
Simple scene, only a cube.
Any idea?
Best H
edit: it exports ',' instead of '.' for vectors
Post by OnoSendai » Thu Sep 11, 2014 1:38 am
Indigo only supports '.' as the decimal separator.
Post by StompinTom » Thu Sep 11, 2014 7:37 am
Must be a locality / language thing... It exports '.' for me. Will have a look, maybe there's an easy way to force using '.'.
Haven't had much free time at all lately, but hopefully will upload some material stuff and this fix at some point soon.
CHF
Post by CHF » Thu Sep 11, 2014 8:20 pm
Probably, while on a german win8.1 64, Rhino is running in English language.
Best H
