SkIndigo 3.8.6.1
Re: SkIndigo 3.8.6.1
Post by Zom-B » Thu Aug 14, 2014 3:00 am
Oscar J wrote:Where the heck do you find all those pdf's?
Lets say I have some nerdy hobby of knowing stuff without understanding it :lol:
Post by OnoSendai » Thu Aug 14, 2014 3:19 am
Zom-B wrote:
Pibuz wrote:Wonderful! And no offence to Zom-B but...A-AH! We're first this time! You want it and you can't have it!!!! A-AH-AH! :lol:
Well, you guys deserve it :wink:
Pibuz wrote:About the test: it's actually cool but I can still se some repetition, which really kills realism.
Yes, regarding that other Scatter PlugIns have for example a Noise falloff for the randomness!
By this for example scale is also controlled by some noise map, Fractal Breakup called in Surface SPREAD for example (Page 15: http://www.c4d-jack.de/html/downloads/s ... Manual.pdf).
Nature doesn't spread uniformly ;)
Some kind of fractal density modifier is pretty easy to add, will think about it.
Post by OnoSendai » Thu Aug 14, 2014 10:17 am
Here we go:
FBM controlling scatter density:
Post by Zom-B » Thu Aug 14, 2014 11:15 am
As usual: awesome!
Post by OnoSendai » Thu Aug 14, 2014 11:24 am
Thanks.
The real tricky thing is adding all the options to the GUI without making it too complicated :)
Post by Zom-B » Thu Aug 14, 2014 11:39 am
OnoSendai wrote:The real tricky thing is adding all the options to the GUI without making it too complicated :)
Well, here I suggest to take a look at the way other Scatter PlugIns arrange it...
ak-sam
Post by ak-sam » Thu Aug 14, 2014 2:39 pm
Is it possible to use an image to control scattering? Hue or RGB value maybe. That would work great for mountain ranges where snow stays clear but rocky bits get different densities of rocks on them. Grass on a lawn could be bent on different angles according to a stripey pattern (see attached).
Some Spray or Fur tools have a bend function using a sort of 'wind' effect. This increases naturalness quite a lot on a large scale scenes. Maybe a similar effect could be applied using the sun's position in Indigo?
Maybe a density variable could fade out the scatter density as the distance from the camera increases?
Also, with vegetation, a high density of objects is critical for top-down camera views which highlight the gaps, but far less critical for ones looking from at a low angle (eg across the top of the grass).
Post by OnoSendai » Tue Aug 19, 2014 12:34 am
Uploaded new build that fixes UV problem.
bubs
Post by bubs » Tue Aug 19, 2014 9:02 pm
Not sure if this is a Skindigo issue or Indigo issue, but I'm guessing the former (hence my post here).
None of my external reference are working properly anymore... The texture mapping is all wrong on them... This is happening on all my models, all of which worked previously.
Post by OnoSendai » Tue Aug 19, 2014 9:39 pm
bubs wrote:Not sure if this is a Skindigo issue or Indigo issue, but I'm guessing the former (hence my post here).
What kind of external references? linked IGMS? Or do you mean external meshes?
bubs
Post by bubs » Tue Aug 19, 2014 10:45 pm
Sorry, should have specified.. external mesh .obj files.
Post by OnoSendai » Tue Aug 19, 2014 10:52 pm
Can u send me a simple example scene?
bubs
Post by bubs » Tue Aug 19, 2014 11:44 pm
sent
Post by OnoSendai » Tue Aug 19, 2014 11:46 pm
Cheers.
Post by OnoSendai » Wed Aug 20, 2014 5:09 am
Updated build:
Fixed up tab animation.
Added more decimal points to ScatterEditor spinboxes.
Added support for the simple thin material type.
Fixed material assignment for external OBJ meshes.
Users browsing this forum: Google [Bot] and 25 guests
