Suvakas
Maxigo-07 v.02 (update-21.April 2007)
- Kosmokrator
- Kosmokrator
suvakas one question about the materials....if i need to make a difuse material with SSS how can get this?your material system cant do this....or im wrong...?
- Kosmokrator
well..i cant experiment now cause it's too late and my Pc is quite slow for SSS, but search the forum. Maby you find some settings that help you out. All the parameters supported (well..most of them) should be presented in my medium/sss material. (or if you think something useful is missing, then let me know)
Suvakas
Suvakas
- afecelis
wow Suvakas! great work! you've pretty much covered what U3dreal had! Just tried 07_01b in Max6 and works very nice!!!
I'm gladly surprised by your work.
Many thanks for the exporter, and also for keeping compatibility with older versions of max
- Kosmokrator
hey suvakas or every one may knows....i pick color for the sss material lets say green...render all ok and fine...but if i pick a color lets say blue...0,0,145......this turn out to purple?(?) here may mat settings...any ideas?maybe some exporter bug....?
Is it blue also in the exported .xml?
If so, that's not an export-bug!
I've got the same problem with transparent mats:
Three spheres, normaly specular in 0.6
one was green, fine
one was red, fine
one was "blue" -> purple!
Maybe, there is something wrong with indigo...
Or, blue things imediatley get reddish !?
ONO???
one was green, fine
one was red, fine
ONO???
- Kosmokrator
ok...the exporter are just fine....the problem are only in blue band of light....i think we have here a serius bug....Ono u Know about that?
no.Kosmokrator wrote:[...]
http://www2.indigorenderer.com/joomla/f ... hp?p=11172
- Kosmokrator
WOW....what a chaos......now i understand at least......suvakas may remake the export values to follow this formula...
its simple to calc but boring......
thnx manito!!!
If you want your glas to have this color: <rgb>0.4 0 0.8</rgb>
compute the final numbers like that: <rgb>(1-0.4) (1-0) (1-0.8)</rgb>
will give: <rgb>0.6 1 0.2</rgb>
