Making the Earth
Onizuka
Making the Earth
Post by Onizuka » Mon Aug 04, 2014 10:52 am
I'm trying to make the Earth, and why not some other planets...
But as you can see on the render, I have a problem on the circumferency of the sphere, where the light of the sun ends, it makes appear the triangles of the 3D sphere, and there is this hapening whatever the inclination of sun. Does any one have an idea to resolve this ?
Its made of one sphere with the Earth texture on it, and a bigger sphere with a PNG image of the clouds.
The Earth texture has a phong material and some bump mapping, And the cloud texture is a diffuse with some bump mapping too.
Everything is at real scale...
Any idea please ?
I also tried to add a third sphere with the fog material from the material database, but if it solve the problem, it blur the whole earth...
And here the same view with only the sun, you can see the triangles of the sphere...
first with sky light and sun, no problem, but its not really accurate for an in space image
Re: Making the Earth
Post by Oscar J » Mon Aug 04, 2014 9:02 pm
Why not make the displacement of the planet more high res?
bubs
Post by bubs » Mon Aug 04, 2014 10:17 pm
Looks like a SketchUp smoothing issue to me...
Post by Oscar J » Mon Aug 04, 2014 10:20 pm
No, no, Indigo always does that with sharp sunlight coming in to a low res mesh at a low angle.
bubs
Post by bubs » Mon Aug 04, 2014 10:25 pm
Ok, can't say I ever tried something like this.
Onizuka
Post by Onizuka » Mon Aug 04, 2014 10:54 pm
Thanks for the answers !
Well I guess its not the geometry because its a 20000 poly components... but why not...
The resolution of the map is 4k i think something like 8000*4000 pixels. The bump map is based on the texture so has the same resolution
Post by Zom-B » Mon Aug 04, 2014 11:23 pm
You may check out this here if you go for some earth atmosphere simulation:
http://www.indigorenderer.com/forum/vie ... 72#p127472
Indigo can do some nice stuff here: http://www.indigorenderer.com/images/at ... simulation
Onizuka
Post by Onizuka » Mon Aug 04, 2014 11:52 pm
Thanks
I've seen this pages, but I dont see where are the explanations to create this earth atmosphere and its blue halo
Post by Zom-B » Tue Aug 05, 2014 12:14 am
Onizuka wrote:I've seen this pages, but I dont see where are the explanations to create this earth atmosphere and its blue halo
There is some download file attached in the Forum post...
Onizuka
Post by Onizuka » Tue Aug 05, 2014 12:22 am
Oh okay well i must have missed it on my mobile... I will go check again ^^
Onizuka
Post by Onizuka » Tue Aug 05, 2014 12:40 am
I've seen, but how can I use the atmo material of the pig file scene, into my own scene ? can't I save the atmo material as a material, to import it in my scene ? How do I do please ?
"Edit" Ok I am sorry I've just found how to save materials
Onizuka
Post by Onizuka » Tue Aug 05, 2014 1:31 am
Well that's what I got whith this atmosphere material ^^
lol
Any suggestions ?
And here I changed the 4K earth texture to the same in 10k... but we still see the triangles of the globe...
Here I removed the atmosphere wich we can see just behind the earth, her reflecting on the atmosphere, and very far, the moon...
I got only a half of the atmosphere I don't know why
Post by Zom-B » Tue Aug 05, 2014 1:48 am
Onizuka wrote:Any suggestions ?
Yes, scale is VERY important here!
If your earth sphere is only 200cm big, the atmosphere will be quite... thin ^^
Post by CTZn » Tue Aug 05, 2014 2:11 am
the shadow terminator issue here is best adressed by using sphere primitives for celestial bodies. If you were to need the use of displacement, then the sphere mesh should be subdivided 3 to 5 times as per normal.
edit: also on clouds I could not make a spherical projection up, making my model work at poles only.
Onizuka
Post by Onizuka » Tue Aug 05, 2014 2:24 am
Well everything is at real scale, the Earth is 6378137 meters large for a half diameter (dont know the word in English), and the clouds are at 10000meters high from the surface of the Earth.
But in fact I didn't scale correctly the atmosphere... but I m not sure how big I should set it up to be correct in real scale, since the real atmosphere is not clerly delimitated by a physical sphere
