help creating a shaded material
elDiego
Post by elDiego » Thu Jul 31, 2014 9:10 pm
Hi, i'm building this pieces and i wanted to look like this (see image) I'm thinking I need somehow two materials (glass and mirror) that fade into each other. any help will be much apreciated.
bubs
Re: help creating a shaded material
Post by bubs » Thu Jul 31, 2014 10:12 pm
Use a gradient map to blend between a Chrome material and a glass material...
bubs
Post by bubs » Thu Jul 31, 2014 10:13 pm
here's what I used. Hope it helps.
Chome Plated Glass.pigm
(1.01 MiB) Downloaded 378 times
elDiego
Post by elDiego » Thu Jul 31, 2014 10:29 pm
Hi Bubs, thanks for the reply. I cant open your scene. i get this message
Error: Failed to parse material: Found unexpected element 'max_extinction_coeff'. (In element 'basic', around line 6, column 9)
bubs
Post by bubs » Thu Jul 31, 2014 10:36 pm
I'm afraid I've no idea what that means... It works for me OK.
Here's the blend map I used. Just use the preset 'Glass' or 'Tinted Glass' as Material A and the NK data preset for Chrome as Material B.
elDiego
Post by elDiego » Thu Jul 31, 2014 11:42 pm
Thanks, I'm far from being a pro, so I don't really know how to create a blend material from scratch ( I tried with no luck)
I do have my ways around it though. I used this material and modified the image to yours, which works fine. but what if that non translucent material to be mirror?
So when it comes to blend materials you have a material A and B , what does the blend number below do? and how can i add a new material to the blend?
Etched_Glass.pigm
(11.57 KiB) Downloaded 299 times
bubs
Post by bubs » Fri Aug 01, 2014 12:02 am
Create new material.
In Property editor choose 'Blend' from drop down menu.
Under the 'General' section choose 'texture' from the drop down menu and put in the texture I posted.
For Material A choose 'specular' and click the + to add medium.
For Material B choose 'phong' and choose cr.nk from the 'Nk data' drop down menu.
That's it!
Post by Zom-B » Fri Aug 01, 2014 3:05 am
elDiego wrote:Hi Bubs, thanks for the reply. I cant open your scene. i get this message
Update Indigo to the latest version!
http://www.indigorenderer.com/forum/vie ... =1&t=13163
elDiego
Post by elDiego » Fri Aug 01, 2014 4:43 am
I think I'm getting there, what do you think? just wish the fading was a bit more drastic.
thanks for the help!
ps. it doesn't let me attach the material
Post by Zom-B » Fri Aug 01, 2014 4:47 am
elDiego wrote:just wish the fading was a bit more drastic.
Just change the gradient map to fit your needs, it controls the fading. Double check that you use gama 2.2 for the texture in Indigo!
elDiego wrote:ps. it doesn't let me attach the material
Yes, maximum attachment size is 0.5 MB, that sucks!
elDiego
Post by elDiego » Fri Aug 01, 2014 8:13 pm
hmmm..., what is the gama 2.2 for the texture. sorry if you find this obvius
bubs
Post by bubs » Fri Aug 01, 2014 8:37 pm
See below
galinette
Post by galinette » Fri Aug 01, 2014 10:11 pm
For a blend map, I'm not sure a gamma of 2.2 is always the best choice. If your gradient varies linearly from 0 to 255, a gamma of 1 will ensure that materials are blended linearly.
A gamma of 2.2 will unbalance towards material A.
Eclat-Digital Research
http://www.eclat-digital.com
bubs
Post by bubs » Fri Aug 01, 2014 10:29 pm
galinette, when it comes to ANYTHING to do with textures I will bow to your knowledge! 8)
Post by Zom-B » Fri Aug 01, 2014 10:31 pm
galinette wrote:For a blend map, I'm not sure a gamma of 2.2 is always the best choice. If your gradient varies linearly from 0 to 255, a gamma of 1 will ensure that materials are blended linearly.
Correct me if I'm wrong, but a gradient created in PS or GIMP, saved as a RGB texture with gamma 2.2 (per default!) needs to be set in Indigo to have gamma 2.2 too, otherwise you get a shift in gradient strength.
I would really like some automated gamma extraction from textures and setting it correctly by default, so such "mistakes" are prevented from the start.
***EDIT***
Actually it seems I'm wrong here, did some test using that map for displacement, since its the best way to actually SEE whats going on:
