SkIndigo 3.8.6.1
lape
Re: SkIndigo 3.6.8.1
Post by lape » Wed Jul 30, 2014 7:11 pm
OnoSendai wrote:Updated build, fixed the hedge instancing.
Thank you, now it works! :D
Do you have a solution about the problem with the environment map? Whatever render method I use, the model turns black, as if the "add sun" option doesn't work. If there is no solution, I will have to uninstall this version and use the previous one :?: (need to finish my project until this weekend).
Lars
24 hours isn't enough
http://www.werkraum3d.com
bubs
Post by bubs » Wed Jul 30, 2014 8:19 pm
@Lape
Do you definitely need to use the 'add sun' option? Have you tried upping the gamma on the Env Map to get sharp shadows?
bubs
Post by bubs » Wed Jul 30, 2014 8:26 pm
@Ono
It seems that the mesh subdivisions under 'Edit Active Mesh' only work on grouped objects now? Not really an issue just wondering if it was intentional.
lape
Post by lape » Wed Jul 30, 2014 8:42 pm
bubs wrote:@Lape
Yes, I need the sun option. Only Env Map with gamma doesn't give me shadows. My model is placed in a photo, so model and photo shadows should be similar. I always take my own panorama at the site and use ptgui to create a hdri or exr env map, then use it for my model for lighting and reflections. This worked fine until 3.8, though there always were issues about balance between env map and sun.
Post by OnoSendai » Thu Jul 31, 2014 1:18 am
bubs wrote:@Ono
Hi bubs,
It used to be possible to subdivide *all* top-level geometry (geometry not in a component definition/instance). I don't think it's a good idea to allow this, and it's not possible now.
Post by OnoSendai » Thu Jul 31, 2014 2:41 am
Updated build:
Added arch glass option to specular.
Removed thin glass material type.
Made subdivision view-dependent option off by default.
Post by OnoSendai » Thu Jul 31, 2014 2:42 am
lape wrote:Do you have a solution about the problem with the environment map? Whatever render method I use, the model turns black, as if the "add sun" option doesn't work. If there is no solution, I will have to uninstall this version and use the previous one :?: (need to finish my project until this weekend).
Have fixed this issue in Indigo, making a new build currently.
lape
Post by lape » Thu Jul 31, 2014 7:51 am
OnoSendai wrote:Have fixed this issue in Indigo, making a new build currently.
That would be cool 8)
Post by OnoSendai » Thu Jul 31, 2014 11:07 pm
lape
Post by lape » Fri Aug 01, 2014 1:23 am
Thank for the update,but now I get this:
The option for light layers doest not work in Indigo, and I only get lighting by env map, no sun... :?
Or did I miss something?
lape
Post by lape » Fri Aug 01, 2014 1:26 am
...when I set sun weight to 1 or any else value thsi happens:
An error occurred while SkIndigo was exporting the scene.
Please copy and paste the following details into an email to support@indigorenderer.com:
SkIndigo version: 3.6.28.3
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Error during processing: undefined local variable or method `used_layers_array' for #<IndigoExporter:0xbeeceb8>
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:10019:in `export_environment'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:955:in `export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:11606:in `block in <top (required)>'
-e:1:in `call'
lape
Post by lape » Fri Aug 01, 2014 2:05 am
oooops, all my fault. :shock:
just forgot to reinstall latest SkIndigo exporter! Now everything works. Env map +sun ok.
Thank you Ono, you saved my weekend! :mrgreen:
Post by OnoSendai » Fri Aug 01, 2014 2:07 am
lape wrote:oooops, all my fault. :shock:
great :)
Post by OnoSendai » Sat Aug 02, 2014 12:16 am
Some more optimisations, subsequent exports of test scene are down to 0.5s (originally ~20s).
bubs
Post by bubs » Sat Aug 02, 2014 12:17 am
All you need to do now is get the same level of speed increase the for the rendering! :lol:
Thanks by the way! great work!
