Blendigo 3.6.28.0
Blendigo 3.6.28.0
Post by fused » Wed Jul 02, 2014 8:02 pm
Archive: http://downloads.indigorenderer.com/dis ... 6.28.0.zip
Windows Installer: http://downloads.indigorenderer.com/dis ... taller.exe
Changelog:
3.6.28.0
* Fixed memory leaked during export to Indigo.
* Applying world scale to orthographic camera sensor.
* Added "Use output directory for .igs files" switch in render settings.
3.6.26.0
* Added 'Shadow pass' render mode.
Bug reports and comments welcome!
Re: Blendigo 3.6.28.0
Post by Oscar J » Wed Jul 02, 2014 8:25 pm
dakiru
Post by dakiru » Thu Jul 03, 2014 12:37 am
Great, thank you!
aleksandera
Post by aleksandera » Thu Jul 03, 2014 2:21 am
Thank you :)
FakeShamus
Post by FakeShamus » Thu Jul 03, 2014 4:26 am
were there some changes made to motion blur? one of my scenes has a BG sphere rotating and the positioning is different with the new exporter.
Post by Oscar J » Fri Jul 04, 2014 12:32 am
The exporting seems to be an awful lot slower... at least in the scene I'm working on right now.
Post by Oscar J » Fri Jul 04, 2014 1:08 am
Nevermind, realised what it was.
Post by StompinTom » Fri Jul 04, 2014 1:56 am
Much thanks for this.
Problem with duplis / particles:
- The percentage under Display now limits the particles exported. Display should only be used to control viewport density / speed up navigating. The full particle count should be used for exporting, as before.
- It is much, much slower now (and in the past couple of Blendigo releases). Meaning, even 2000 particles takes about 20 seconds to export, whereas before I could comfortably export over a million particles much quicker. Did particle export change? Perhaps an idea would be to make a binary scene format, like .igmesh, so each particle doesn't have to be written out to an XML file (I imagine string conversion slows things down... ?)?
FakeShamus
Post by FakeShamus » Fri Jul 04, 2014 2:37 am
I've noticed this too - previously I could export a ridiculous amount of particles, hundreds of thousands, easily from blendigo in a reasonable amount of time.
now I can go grab a coffee while it works on like 10 or 20 thousand.
Post by fused » Fri Jul 04, 2014 10:37 pm
not entirely sure what's causing the slowness, will look into it soon.
Sorry about the inconvenience.
Post by fused » Wed Jul 09, 2014 12:12 am
FakeShamus wrote:I've noticed this too - previously I could export a ridiculous amount of particles, hundreds of thousands, easily from blendigo in a reasonable amount of time.
Can't seem to reproduce that. Can you send me a scene?
Post by fused » Wed Jul 09, 2014 2:55 am
Actually, we have found something. It should be a lot faster soon!
FakeShamus
Post by FakeShamus » Wed Jul 09, 2014 4:06 am
awesome!
I may have been exaggerating a bit. I was just trying to reiterate what StompinTom noted.
...oh, also a plus 1 for the display vs render percentage for particles, it makes it so much better to be able to hide most of them in the viewport.
Post by StompinTom » Wed Jul 09, 2014 3:50 pm
fused wrote:Actually, we have found something. It should be a lot faster soon!
Cool! Can you give a hint at what it may have been? I've been looking over the Blendigo code - out of interest and to fiddle around with it. I'm slowly learning some Python and it's cool to see how stuff is done 'properly', especially with Blender.
Post by OnoSendai » Thu Jul 10, 2014 12:47 am
You can see the fix here:
https://code.google.com/p/blendigo/source/detail?r=44
Unfortunately there's some whitespace changes mixed in as well.
