Some new work
Re: Some new work
Some actual paid for work
for a very good friend of mine. Good fun on a tight timeline
Re: Some new work
Fantastic, your grass technique is spot on!
You sicko: you've put the water grid outside the doors..
Great detailing!
Re: Some new work
Top stuff.
Not a fan of the fake DOF on the nearby grass though
Re: Some new work
Fake! I'm hurt!OnoSendai wrote:Not a fan of the fake DOF on the nearby grass though
Re: Some new work
It's easy to see because the blur is a bit much and the transition is too sharp.
Glad the client liked it though
Re: Some new work
Was about to say that about the DOF as well. It's easy to make good DOF in photoshop. Just use the gradient tool to create a gradient that goes along the ground, and use that gradient with the lens blur tool.
Otherwise great work!
Edit: take a look at my post here:
http://www.indigorenderer.com/forum/vie ... 6&p=126303
Re: Some new work
Yes I normally use the depth pass to produce just that effect, but as I said this was a bit of a rush job, and obviously it shows...
Re: Some new work
Awesome results mate, really well done!
Third image misses some grass on the left border ^^
Re: Some new work
thanks! And yes you are correct about the grass... I'd say 'well spotted' but really from you I'd expect nothing less!Zom-B wrote:Awesome results mate, really well done!
Re: Some new work
Close-up view of the brick house I've been tinkering with. Thought I'd try a black and white version too...
Re: Some new work
you do know the beam soffit / construction would very likely never look like that?bubs wrote:Close-up view of the brick house I've been tinkering with. Thought I'd try a black and white version too...
Re: Some new work
@juju - this is a real house, and the soffit looks exactly like that.
http://www.indigorenderer.com/forum/vie ... 1&start=45
Re: Some new work
ahhh, so a brick skin clad/tiled concrete beam then?bubs wrote:@juju - this is a real house, and the soffit looks exactly like that.
Re: Some new work
There is a concrete beam as a lintel over the large opening and then full bricks are hung from this with proprietary masonry hangers, not really very difficult, but looks good.
A bit like this (only with concrete beam not steel)
