SkIndigo 3.6.28.3 (beta)
Hello,
This is a bugfix release. See changelog below for details.
This is a beta release - please test. Please install Indigo 3.6.26 or newer before this version. Get it from here: http://www.indigorenderer.com/forum/vie ... =1&t=12701
To Install:
On windows, you can use the Windows installer.
Otherwise:
1) Download RBZ file from link below
2) In SketchUp, go to Window->Preferences->Extensions
3) Uncheck the SkIndigo checkbox, press OK, restart SketchUp
4) In SketchUp, go to Window->Preferences->Extensions->Install Extension
5) Select the RBZ file you downloaded
6) Check the SkIndigo checkbox again.
7) Restart Sketchup again.
NOTE: this elaborate process is to make sure the asset files get updated properly, which doesn't work if the extension is enabled.
Changelog:
Fix use of bytesize in older versions of ruby.
Catching exceptions raised during export, and showing an error message dialog.
RBZ file: (all platforms)
http://downloads.indigorenderer.com/dis ... 6.28.3.rbz
Windows Installer:
Let us know if there are any problems with this beta release!
To Install:
Otherwise:
Changelog:
Windows Installer:
Re: SkIndigo 3.6.28.3 (beta)
Sorted. Thanks Ono
great!bubs wrote:Sorted. Thanks Ono
Works! Many thanks ONO!OnoSendai wrote:great!bubs wrote:Sorted. Thanks Ono
Hope I didn't speak too soon... it's still exporting fine, but when I click on the camera icon to change my settings I get the below error.
Have updated builds in-place. Please download again and try.
Yep that's fixed it. Thanks again.
Ono, do you mind updating a little the SkIndigo Gui, in order to avoid misunderstandings when using the not-working-anymore "glass acceleration" advanced property? A "fast glass" checkbox should be added in the specular shader panel instead, in my opinion, since this is now a material-dependent property, and not a scene property anymore.. Am I right?
Hi Pibuz,Pibuz wrote:Ono, do you mind updating a little the SkIndigo Gui, in order to avoid misunderstandings when using the not-working-anymore "glass acceleration" advanced property? A "fast glass" checkbox should be added in the specular shader panel instead, in my opinion, since this is now a material-dependent property, and not a scene property anymore.. Am I right?
We'll make those changes for a 3.8 version of SkIndigo, which we will do soonish.
Many thanks!
williamhhf
Re: SkIndigo 3.6.28.3 (beta) ErrorLoad
Hi OnoSendai, my sketchup and skindigo keep pop up this problem, if i open/create a new sketcup file does not effect anything, but the ready made sketchup file or save from new sketchup file, it will be happen like this, please help!
