Sroka8888 Rendering Thread
yonosoy
Re: Sroka8888 Rendering Thread
Post by yonosoy » Fri Feb 14, 2014 8:23 am
Hi Sroka.
It's the way the subdivision algo works!
The first half of subdivision are "globals" (X4,X4,X4,...). Then do the from view dependents (check the renderlog).
Probably it is necessary other kind of algo for this purposes.
At the moment the option is a large amount of polygons for the base and only 3 , 5 subdivisions (take an even option (then the last is view dependent).
Good luck !!
(this is an observation for pre-displaced terrains).
subpixel
Post by subpixel » Fri Feb 14, 2014 10:24 am
Sroka8888 wrote:earlier i render grass scene and in this scene have 200mil poly and only 8gb ram "eat".
I now test import this terrain and render - 5mil poly - crash system ( eat all RAM, system stuck ) - what is a problem?
Not sure if that was the case, but I suspect there was only a fraction of unique triangles in grass scene. With instancing you can easily have 200+ million triangles with only handful of unique triangles, which are stored in memory.
Hope it makes sense.
Sroka8888
Post by Sroka8888 » Fri Feb 14, 2014 10:54 am
yonosoy: Thanks for advice :wink:
subpixel: Yes, yes you are right :wink: I forgot about it.
Mateusz Sroka
Platige Image - Lighting / Shading / Look Development Artist, Environment Artist
Sroka8888
Post by Sroka8888 » Sun Feb 23, 2014 12:04 pm
Some tests:
Mateusz Sroka
Sroka8888
Post by Sroka8888 » Mon Mar 03, 2014 8:29 pm
More tests:
Mateusz Sroka
Voytech
Post by Voytech » Tue Mar 04, 2014 7:07 am
The detail in that last glass shot is seriously impressive!
Sroka8888
Post by Sroka8888 » Thu Mar 06, 2014 10:05 am
7min for render :)
Mateusz Sroka
Sroka8888
Post by Sroka8888 » Thu Mar 27, 2014 5:44 am
New:
Mateusz Sroka
Post by Pibuz » Thu Mar 27, 2014 6:22 am
Your bread is really cool! Is that modeled or displaced?
Sroka8888
Post by Sroka8888 » Fri Mar 28, 2014 6:00 am
Pibuz: Model - This is my first 3D scanning.
Mateusz Sroka
Post by Oscar J » Fri Mar 28, 2014 6:34 am
Cool!
Post by Zom-B » Fri Mar 28, 2014 9:12 am
Sroka8888 wrote:Pibuz: Model - This is my first 3D scanning.
Agisoft Photoscan??!
Your results look great, what "scanning hardware" did you used?
Polinalkrimizei
Post by Polinalkrimizei » Fri Mar 28, 2014 7:59 pm
What a great way to make food renderings - looks delicious!
Would also like to know more about the scanning process...
Inspiring thread btw!
Sroka8888
Post by Sroka8888 » Fri Mar 28, 2014 11:33 pm
Zom-B: Canon A590 + 123d catch + Meshmixer ( I try also VisualSFM with CMVS-PMVS + MeshLab)
Polinalkrimizei: All about scanning process - here: http://www.123dapp.com/howto/catch
Mateusz Sroka
Post by OnoSendai » Fri Mar 28, 2014 11:36 pm
That's pretty cool :)
