libpng warning: Incompatible libpng version in application and library
libpng warning: Application was compiled with png.h from libpng-1.2.42
libpng warning: Application is running with png.c from libpng-1.4.3
libpng warning: Application is running with png.c from libpng-1.4.3Fixed for next release, thanks for report.Sroka8888 wrote:Good Work !
Problem: Online Material Database don't find any materials.
Should be fixed for next release.Prof4D wrote:Does Not work for XP
The Point of the entry in procedure inet_pton is not found in library DLL WS2_32.dll.
Yes, please do.Patrice wrote:Curious bug with Indigo RT 3.8 (bidir, mlt ...)
Not on 3.6
Just a plan and a street lamp
Can send the simple test scene.
Process: Indigo [3961]
Path: /Applications/Indigo Renderer/Indigo.app/Contents/MacOS/Indigo
Identifier: com.apple.IndigoRenderer
Version: 3.6 (244)
Code Type: X86-64 (Native)
Parent Process: launchd [199]
Responsible: Indigo [3961]
User ID: 501
Date/Time: 2014-02-15 08:59:40.454 -0500
OS Version: Mac OS X 10.9.1 (13B42)
Report Version: 11
Anonymous UUID: 3D654746-4BE0-49B7-A4C1-6F30DE992CE7
Sleep/Wake UUID: AD211865-05F0-48D0-A0CE-CE4F6E8DAB8A
Crashed Thread: 15
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000060fe001ef704Sure you are using version 3.8.0 here???FakeShamus wrote:Code: Select all
... Version: 3.6 (244) ...
Win, OS, Linux?Rado Volmut wrote:speedup is great, but I have problem with slaves , after installing version 3.8 ( master and slaves too ), slaves can´t connect to master server.
We have Win7, when I was updating 3.6.x along a time wasnt needed fix firewall, but I will try it now.Zom-B wrote:Win, OS, Linux?Rado Volmut wrote:speedup is great, but I have problem with slaves , after installing version 3.8 ( master and slaves too ), slaves can´t connect to master server.
No issues here on win 8.1 64bit, but my firewall needed new confirmation to allow the new EXE's connect via LAN!
my slaves are still disable to connect to master. I shutdown whole firewall ( we have ESET ) on master computer and slaves too. it´s issue on the side of beta version 3.8 , or ?Rado Volmut wrote:We have Win7, when I was updating 3.6.x along a time wasnt needed fix firewall, but I will try it now.Zom-B wrote:Win, OS, Linux?Rado Volmut wrote:speedup is great, but I have problem with slaves , after installing version 3.8 ( master and slaves too ), slaves can´t connect to master server.
Process: Indigo [42837]
Version: 3.6 (244)
Parent Process: launchd [143]
Date/Time: 2014-02-22 14:45:02.260 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 347531 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 5445 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: 89890EC5-DD1F-497B-9089-CF394F53D97B
Exception Codes: KERN_INVALID_ADDRESS at 0xffffffff27d01dc4
Crashed Thread: 19Maybe a stupid question, but does this behavior happen to you also using the testscenes inside the Indigo folder, using their default settings?FakeShamus wrote:doesn't sound like anybody else is having problems with this new version, but I continue to get crashes with errors such as this...
Users browsing this forum: No registered users and 123 guests
