Noob question!
8 posts • Page 1 of 1
danyolgiax
Noob question!
Post by danyolgiax » Thu Mar 01, 2007 4:37 am
Sry for this noob question:
How can i create a perfect reflective sphere in blender and render it in indigo?
i've tryied but i've a black hole instead the sphere!
(Blender 2.46, Indigo 1.1.5, Blendigo 1.1.5)
Post by Kram1032 » Thu Mar 01, 2007 4:44 am
Set IOR >1 ;) (The higher, the brighter the reflection -> perfect mirror at 100000 IOR...
Which exporter do you use? And which Indigoversion?
If you use IndigoV 0.7.x, I'd say, you should use Blendigo!
If you use 0.6.x, you have to hand-edit the xml and increase the IOR value by your self...
danyolgiax
Post by danyolgiax » Thu Mar 01, 2007 4:47 am
Kram1032 wrote:Set IOR >1 ;) (The higher, the brighter the reflection -> perfect mirror at 100000 IOR...
and for a perfect sphere??
in my signature:
(Blender 2.43, Indigo 0.7, Blendigo 0.7t5 beta 3)
Post by Kram1032 » Thu Mar 01, 2007 4:59 am
Perfect sphere is easy too^^
Just create an icosphere (between 3-5 subdivs) and name it xyz.sphere
(I.E. Mirror.sphere)
As I don't know, if it should be in OB or in ME, I just rename both fields ;)
This sphere-primitive doesn't work with meshlight, how ever....
With the same trick, you also can add an infinite plane: just name it xyz.plane :D
Sorry, I didn't look in your signature :oops:
kepler
Post by kepler » Thu Mar 01, 2007 5:08 am
Kram1032 wrote:As I don't know, if it should be in OB or in ME
You should rename the "ME" field, since you want to rename the mesh name.
Post by Kram1032 » Thu Mar 01, 2007 5:24 am
Ok, learned something too^^
danyolgiax
Post by danyolgiax » Thu Mar 01, 2007 7:09 am
Kram1032 wrote:Sorry, I didn't look in your signature :oops:
np guy! ;-)
tnx for replies!!
Post by Kram1032 » Thu Mar 01, 2007 7:17 am
np from my side : 8) :arrow: :wink: :arrow: :) :arrow: :D :arrow: 8)
