hi, I'm having issues with my render. for some reason its coming blurry and i was just rendering the same model but another view and it came alright.
anyone knows what I'm doing wrong if i'm doing something wrong?
does it have anything to do with the material maybe? (i'm rendering a scracth metal)
here is an example.
help - blurry render
Re: help - blurry render
Yes, that's depth of field effect. Your camera points to the environment (in the center of the image) which is at infinity, and as you likely activated autofocus, it focuses on an infinite distance.
Just either:
- Disable camera autofocus and set manually the focus distance to the approximate object's distance
- Or center the view on the object, autofocus will now work as expected
Etienne
Just either:
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Thanks Etienne, I picked the focus point manually and that fixed the problem.
best.
best.
