Arrow textures HELP
5 posts • Page 1 of 1
tarikb
Arrow textures HELP
Post by tarikb » Sun Sep 29, 2013 11:06 pm
I have downloaded arrow textures, and every mat have 3 textures :
1. Difuse map (d100) -- This is normal map??? what is d100?
2. Bump map (d005) -- Bump map is 005 = 0.05m
3. Specular map (s050, g050) how???
I don't know how to use it properly, where to put SPECULAR MAP and how?? please help..
Thanks
Skindigo
noldo
Re: Arrow textures HELP
Post by noldo » Mon Sep 30, 2013 12:03 am
Hi.
DIFFUSE is the COLOR for indigo material.
Put the bump obviously in the bump map of indigo material, and set the intensity according to the texture size.
For the specular map, s050 is the specularity setting, g050 is the glossiness setting
If you put the map in the exponent, you can control the glossiness.
If you put the map in the fresnel scale, you can control the amount of specular intensity.
I think the numeric value is for max-vray setting...
tarikb
Post by tarikb » Mon Sep 30, 2013 3:56 am
i use SKETCHUP and i have texture for SPECULAR, texture for MAT, and texture for BUMP, i don't know where to put specular map, how to chose exponent or fresnel scale ? Thanks
Skindigo
Post by Pibuz » Mon Sep 30, 2013 10:33 pm
exponent channel, takrib.
Just make it much more contrasted: specular maps from arroway are good for vray settings, we need much contrast to work with them in Indigo.
Post by Zom-B » Mon Sep 30, 2013 11:23 pm
Check this out tarikb: http://www.arroway-textures.com/en/faq/14#14n310
I also advise you to use the specular map in the FresnelScale chanel too, since here you actually control reflectivity.
In the exponent channel you only control the glossiness of the reflections!
