water
bubs
Re: water
Post by bubs » Wed May 01, 2013 9:17 pm
Ok, don't know if anyone else has encountered this but...
I have not been able to get caustics through water to work for some time, despite following the instructions in this thread. Finally through a lot of trial and error (and a large amount of bad language) I finally discovered that the caustics don't work for me if the underlying texture (pool tiles etc) has a bump applied.
No idea if this is a known bug or just me being stupid about something that's been mentioned before... but anyhow I turned off the bump on my pool walls and hey presto, caustics!
I'm using SketchUp 8 and Indigo 3.4.18
Re: water
Post by OnoSendai » Wed May 01, 2013 10:01 pm
Hi bubs,
I'm aware of the issue.
The problem is is that the uneven surface normals on the pool bottom when you use bump mapping make it a lot harder for MLT. The caustics will still appear, that will just take a lot longer.
Bosseye
Re: water
Post by Bosseye » Thu May 02, 2013 3:51 am
Interesting - I have a small bump map applied to my blue pool tiles in the images already posted and the caustics show up pretty much straight away.
The problem I'm having is that for no obvious reason I can't see the caustics when looking into the pool from above anymore. Need to recreate my steps and see where I introduced the issue I suppose.
I've also been trying to model a half and half view showing the outside surface and the caustics underwater, but I can't figure a way to do it. I thought I might be able to just position the camera half and half and then adjust the water volume so that it sits in front of the camera but of course, the water material on the side facing the camera just distorts everything. So I tried taking that entire plane out which gives you the sharp edge, but the water is no longer a closed volume so caustics no longer work. Tried putting a thin glass plane in front instead and still distorts.
Remind me, is there a way to tag a texture or a geometry plane so that it renders (or rather doesn't render) invisible in Indigo? SO I can close the water volume but remove the side that distorts the view....or is that a dumb question! :lol:
Re: water
Post by OnoSendai » Thu May 02, 2013 4:07 am
Bosseye:
Rendering caustics when seen from above the pool is fundamentally a much harder problem for unbiased renderers than rendering caustics from inside the pool. This is because it becomes an SDS (specular diffuse specular) problem, which is hard for unbiased renderers. This is why MLT bidir works best for this kind of scene.
Re: water
Post by Headroom » Thu May 02, 2013 12:57 pm
There are a lot of good tips in respect to caustics in CoolColJ's test pic thread:
http://www.indigorenderer.com/forum/vie ... &start=615
Mongoose
Re: water
Post by Mongoose » Thu May 02, 2013 8:50 pm
i wish i could of understand more on Upgrading my renderings, sometimes it takes alot of time to just render one scene.. and i have a pretty beastly machine working on.
if im not mistaken i read somewhere inside the link you posted that nmcr rate is directly improving wait time during the rendering... i had no idea of the vast depth of rendering techniques i wish to know more...
Sketchup 8, Sketchup 2013 Pro
AutoCad 2013 Architectural,
indigo 3.4.16
ROG - ASUS - X79 Sabertooth
Intel I7-3930K 12 Threads
NVIDIA - GTX670 DC II
16 GB - Corsair Vengeance With Applied Cooling
Noktua NH-D-14
128 - OCZ SSD Vertex IV
PowerMax
Re: water
Post by PowerMax » Thu Jul 25, 2013 8:10 am
Hey~ I tried a little with your way, but it seems have huge problem with the water surface. and no matter what I do, the water still has no color, I like the color of your water, how did you do that~
Bosseye wrote:Aha! but if I leave view dependant on, leave subdivision smoothing off and set curvature threshold to 0 instead of 0.1 it works...
Thanks for your help :D
The attachment CausticsWorking.jpg is no longer available
The attachment CausticsWorking2.jpg is no longer available
EDIT: Wahey! I Like this. It has absolutely no practical application for anything that I use Indigo for, I'll never have a need to render underwater caustics, but its still very clever indeed.
The attachment CausticsWorking3.jpg is no longer available
Bosseye
Re: water
Post by Bosseye » Mon Jul 29, 2013 8:12 pm
Hi, to change the colour of the water I simply changed the material colour in Sketchup using the colour wheel so it has a slight blue/green tint to it. Job done :D
Not sure why you're getting the 'oily' colours effect on your surface though. Perhaps its the tracing method you're using? I used BiDirMLT for all mine.
Re: water
Post by OnoSendai » Sat Aug 31, 2013 5:15 am
Hi All,
I made a tutorial on how to make a pool with caustics in SketchUp:
http://www.indigorenderer.com/documenta ... l-sketchup
Please forgive the basic modelling skills :)
Re: water
Post by Pibuz » Sat Aug 31, 2013 5:37 am
Wonderful!
The displacement shader is excellent, I don't get the whole absorption part though..
It's easier for me to set a little transparency in sketchup and chance the opacity if needed instead of working on the complementary RGB value. :lol:
Re: water
Post by OnoSendai » Sat Aug 31, 2013 5:41 am
Pibuz wrote:Wonderful!
It's a bit hard to visualise. Basically if you want the water to be blue with some green, then you have to absorb lots of red, a little green, and a little less blue.
You get the hang of it after a while :)
Re: water
Post by Whaat » Fri Sep 13, 2013 4:06 am
OnoSendai wrote:Hi All,
Good tutorial but missing something critical for subdivision:
Make sure the entire water volume object is fully selected by triple-clicking on it:
Should say something like:
Triple click to select the entire water volume object, then make it a group or component. (Edit->Make Group)
Then, double click it to make it the active mesh.
Then, right click and select 'edit active mesh'.
The active mesh is NOT the selected faces, it includes ALL the faces in the current editing context.
Can you change this please?
Re: water
Post by OnoSendai » Sat Sep 14, 2013 2:56 am
Yup, will fix.
Edit: Done.
Lal-O
Re: water
Post by Lal-O » Wed Aug 29, 2018 11:08 am
Hi :D
Well...., after almost 5 year this thread was created, i finally join to the chat 8)
I have to render some images where a pool is involved and i just can not create the caustics...I've tried all methoods suggested here and no luck :roll:
This is what i get so far by adding a displacement map to a simple plane group in sketchup ( i do know how the displacement works inside sketchup :wink: )
Plese, just tell me caustics are supported by GPU
Re: water
Post by Headroom » Wed Aug 29, 2018 12:46 pm
Have you switched to CPU rendering and did it work there ?
