SkIndigo 3.6.21 (beta)
2 posts • Page 1 of 1
Post by OnoSendai » Fri Aug 30, 2013 5:31 am
Hello,
This is a beta release - please test. You need Indigo 3.6.0 or greater to use this version.
To Install:
1) Download RBZ file from link below
2) In SketchUp, go to Window->Preferences->Extensions
3) Uncheck the SkIndigo checkbox, press OK, restart SketchUp
4) In SketchUp, go to Window->Preferences->Extensions->Install Extension
5) Select the RBZ file you downloaded
6) Check the SkIndigo checkbox again.
7) Restart Sketchup again.
NOTE: this elaborate process is to make sure the asset files get updated properly, which doesn't work if the extension is enabled.
Some features are WIP. You can now create custom preview scenes by selecting 'New.." from the preview scene dropdown list. You just need to have a material in your scene named 'previewmaterial'. There is no way yet to delete a custom preview scene. They are stored here:
C:\Users\[username]\AppData\Roaming\Indigo Renderer\su_preview_scenes
The 1m scale preview scene is not working fully yet. You can try it out but it does not scale displacement properly yet (it works with absorption and media settings though).
Material loading of the new material types also does not work yet.
Changelog:
#Version 3.6.21
#Added 'Render Selected Entities' button to the SkIndigo toolbar.
#Removed dialog asking the user if they only want to export the selected entities after pressing render.
#Fixed problem with material attributes being copied from last material when a new material is created.
Download: http://downloads.indigorenderer.com/dis ... 3.6.21.rbz
cotty
Re: SkIndigo 3.6.21 (beta)
Post by cotty » Fri Aug 30, 2013 6:14 am
Nice update!
