kklors render stuff
Re: kklors render stuff
Post by OnoSendai » Wed Aug 21, 2013 9:30 am
kklors wrote: @OscarJ: Yeah haha! I emitted over a million low res spheres from the body. Was very tempting to fake them in in post, but decided against it in the end. Here's a wireframe to see the chaos better: http://abload.de/img/wireafba8.jpg
Interesting!
Even though there are a million bubbles, they still seem a bit sparse visually, and significantly larger than they would be in real life. I wonder if you were running into Indigo limitations rendering this scene? I know it can take a while to build the scene when you start getting up around that number of objects.
kklors
Post by kklors » Wed Aug 21, 2013 11:43 am
Yep I agree, it has to do with the front bubbles covering the ones behind. I had the body emitting 20K particles per frame and the render was at frame 74. Also about 1/3 of the bubbles were floating above the water surface at the given frame.
Indigo had no problems at all exporting that. C4D's Render Instances works perfectly well with Indigo be it using a scatterer, cloner or particles. I don't know what happens behind the curtains, but anything that works with Render Instances is very fast and RAM easy.
kklors
Post by kklors » Thu Sep 05, 2013 6:04 am
Eeek a belated one, the flu and work killed me a bit recently.
Gave SS5 and 8 light layers a try : )
Post by Oscar J » Thu Sep 05, 2013 6:30 am
I'm considering putting that on my wall. :)
lape
Post by lape » Thu Sep 05, 2013 6:42 am
looks like tiberium :mrgreen:
24 hours isn't enough
http://www.werkraum3d.com
kklors
Post by kklors » Sun Sep 29, 2013 5:13 am
Thanks people! Big compliment. Maybe I'm going to do stuff for prints one day or render this one out in ultra high res if there's interest.
Still no time for the weekly works at the moment really, but still manage to do them at least once in a while.
Post by zeitmeister » Sun Sep 29, 2013 6:05 am
Hey man,
please seriously think about selling your images to a publisher which is scifi-related...
Post by CTZn » Sun Sep 29, 2013 10:12 am
pretty much mind blowing kklors !
kklors
Post by kklors » Fri Oct 18, 2013 10:09 pm
Thanks people! Goal for next year is definitely to kick out some more refined works as print.
Speaking of which, I'm trough a year of weeklies now and will continue doing them for as long as I can, but will try out more stuff except for environments next year. Unfortunately I only managed to do 42 pieces this year, due to batshit crazy working hours etc.
To celebrate getting trough this year at least a bit I will raffle this week'S piece as a A2 print on my FB page this weekend. So just check by later today or tomorrow at: https://www.facebook.com/kokolores123 if you feel like having it on your wall.
Post by OnoSendai » Fri Oct 18, 2013 11:00 pm
Is that an Indigo render? O_O
Post by Zom-B » Sat Oct 19, 2013 12:05 am
Awesome shit, as usual! Could be some concept art for a Deichkind scenic design!
OnoSendai wrote:Is that an Indigo render? O_O
I would say that if every material becomes a (weak) emitter you end up with such a look (and so few noise!)...
kklors
Post by kklors » Sat Oct 19, 2013 12:41 am
Thanks Ono and Zom!
Yeah it's an Indigo render indeed. There is some post DOF which blurred away quite some noise, but also as Zom said, anything being an emitter was clean right away more or less. Also it obviously looks way less noisy in 1440p than the original that was made for print in 7.5K and later upscaled to 8.3K.
Because rendering in this res was kind of RAM heavy I haven't had the luxery of using tons of light layers this time and only had 3, but saved like 20 or so different light setups and blended them, which altered the look but also removed some noise in places because I was able to take specular and noise ares from differently lit versions.
kklors
Post by kklors » Wed Nov 13, 2013 5:50 am
No weekly, but some random stuff I rendered this night while experimenting with shapes.
FULL 4K: http://abload.de/img/plz8utu.jpg
Post by Oscar J » Wed Nov 13, 2013 7:51 am
Love the second one - great material, whatever it is!
