Bosseye
Post by Bosseye » Mon Jul 29, 2013 7:56 pm
Cars in a pool. For no reason other than I had the pool caustics model set up and a load of new sketchup car models to play with and nothing useful to do with them. SPLOSH!
kklors
Post by kklors » Tue Aug 06, 2013 10:46 pm
Very nice! I've seen in your other thread that you did the caustics with displacement. Is it just for the distortion or does it give a better/different effect?
You inspired me to try rendering some pool too one day : D
Post by OnoSendai » Wed Aug 07, 2013 3:27 am
kklors wrote:Very nice! I've seen in your other thread that you did the caustics with displacement. Is it just for the distortion or does it give a better/different effect?
It's best to displace the water surface if you want the most realistic caustics.
Post by CTZn » Wed Aug 07, 2013 11:22 am
In wich case you are safer with view-dependent subdivisions switched OFF. Best is high density plane with no more than 2-3 subdivs levels.
kklors
Post by kklors » Thu Aug 15, 2013 8:41 am
Thanks for the advice you two! A render intense pool scene currently in the making : P
ENSLAVER
Post by ENSLAVER » Sat Aug 17, 2013 4:39 pm
Been a while, rendered with hybrid (gpu+cpu)
Post by OnoSendai » Sat Aug 17, 2013 11:33 pm
Nice one Enslaver!
cotty
Post by cotty » Sun Aug 18, 2013 12:02 am
ENSLAVER wrote:Been a while
me too...
Post by Zom-B » Sun Aug 18, 2013 12:17 am
nice wood you have there cotty :)
I would suggest you use the map also in Fresnel scale, bump and exponent map, since it looks way to polished like that.
Maye a coated material could shine here too
cotty
Post by cotty » Sun Aug 18, 2013 1:23 am
You are right. I used it for the displacement map, but choose the value too small.
Post by Pibuz » Fri Aug 30, 2013 4:20 am
Just to add a question...
How can we sketchup users add a map as a fresnel map, inside SkIndigo?
@ enslaver: it's on my desktop 8)
Post by pixie » Sun Sep 01, 2013 12:19 am
Trying the invisible lights to add volume to my cherries!
ENSLAVER
Post by ENSLAVER » Tue Sep 03, 2013 11:04 pm
Quick tests made quicker via Rebus.
Post by zeitmeister » Fri Sep 06, 2013 4:20 am
Hell yeah. :shock:
Voytech
Post by Voytech » Tue Sep 17, 2013 3:03 am
A little bit of an overkill on rendering time - 66 hours (let it run over the weekend). Ended up with 8800ssp. Original resolution is 18mp.
