Put it in the RAM
- zeitmeister
Put it in the RAM
Hey,
I was thinking what would happen if Indigo were able to export the scene directly to the machine's RAM?
Optional, for sure?
Export would be a lot faster, and could nearly reach realtime-speed.
For efficiancy, Indigo could check and export only new meshes.
What do you think about that?
Optional, for sure?
Re: Put it in the RAM
You refer to the exporter writing directly into RAM not Indigo itself, right?!
I really like the idea, shouldn't cost any extra RAM at all and give some faster previews, where 10sec export + startup time is a lot if you do previews all the time!
So here is my +1
So here is my +1
Seems like a good idea for wip/preview renders. On a final render the extra 10s is not an issue when you're waiting a few hours anyway.
So yes, +1
So yes, +1
- zeitmeister
Right.
As I said, in junction with the option only to export CHANGED meshes or textures.
Should be lightning-fast.
Hell yes! +1
Using the c4d plugin already doesn't write to disk and uses RAM only
- zeitmeister
Really? But Export is as slow as exporting to the Standalone...
For internal rendering yes... I usually still use the external version, since I can tweak parameters on the fly and take them over to C4D if they fit...OnoSendai wrote:Using the c4d plugin already doesn't write to disk and uses RAM only
Could we still have it for the other exporters?OnoSendai wrote:Using the c4d plugin already doesn't write to disk and uses RAM only
Thats what i requested the Realtime Preview for Cindigo forZom-B wrote:For internal rendering yes... I usually still use the external version, since I can tweak parameters on the fly and take them over to C4D if they fit...OnoSendai wrote:Using the c4d plugin already doesn't write to disk and uses RAM only
That would make your exporting redundant, especially because there's a lot of features not yet supported in the indigo gui but in the exporters
C4D R20 Studio
mad-imagery.com
mad-imagery.com
