community need for renderings
This forum is for discussing the Indigo Website, The community, its organization and the online tools/resources.
SCHMUMS
Re: community need for renderings
Post by SCHMUMS » Thu Jul 18, 2013 9:11 am
there is more than :
•114210252_4_hd
• 114210259_2_hd
to render
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Post by Headroom » Thu Jul 18, 2013 10:06 am
See attached cropped region at 100% magnification
SCHMUMS
Post by SCHMUMS » Thu Jul 18, 2013 10:14 am
I look
Zbrush 4
Post by Headroom » Thu Jul 18, 2013 10:21 am
I sent you a private message.
It would be great if we could upload the images directly to dropbox.
Due to the residual noise the PNG compression is not too effective and the Image size is 22MB, exceeding the size I can send with my iCloud account.
SCHMUMS
Post by SCHMUMS » Thu Jul 18, 2013 5:55 pm
Hello Polinalkrimizei, you could start rendering the 251_2?
I'm beging 114210259_2
it remains 114210252_4
which can compute it?
Zbrush 4
Post by CTZn » Thu Jul 18, 2013 6:36 pm
SCHMUMS wrote:it remains 114210252_4
I have started it (4200x3200, bidir).
I am assuming that you mean "beginning", not "beging" (mendier). Either what I picked the wrong file to render...
SCHMUMS
Post by SCHMUMS » Thu Jul 18, 2013 6:45 pm
Bonjour Adam effectivement je commençais l'image 0259. :)
Merci de ton aide
Zbrush 4
Polinalkrimizei
Post by Polinalkrimizei » Thu Jul 18, 2013 6:47 pm
I'm a work right now (3D is just a hobby to me as you might have noticed :lol: ) and won't be able to start until the evening. I'll do an overnight render until Friday if that helps...
How do I send the first pic? It reached something like 1300 SSP I think and as headroom pointed out, it is 22MB. I could just post my dropbox-link tonight.
Did anybody have the chance yet to compare GPU path tracing vs. BiDir?
Post by CTZn » Fri Jul 19, 2013 12:57 am
After 6h hours and 300spp I'm realizing that
Saving tone-mapped PNG to 'C:\Users\user\AppData\Roaming\Indigo Renderer\renders\im1374129097.png'
Warning: ImFormatExcep: LibPNG error: Write Error
Saving Indigo image (.igi) to 'C:\Users\user\AppData\Roaming\Indigo Renderer\renders\im1374129097.igi'
WARNING: Failed to save IGI: Error while writing IGI to file: Write to file failed.
and I killed the render, sorry. My pc is way too borderline, swapping to disk to update the render and not dumping a thing.
SCHMUMS
Post by SCHMUMS » Fri Jul 19, 2013 1:02 am
argghh!!
as tu une sauvegarde du png?
Zbrush 4
Post by CTZn » Fri Jul 19, 2013 1:10 am
y'a pas de png, il a rien put écrire depuis les premiers samples.
Mon disque est plein mais je ne m'attendais pas à ça. Je voulais pas passer pour un trouduc et t'aider et au final c'est pire... désolé.
edit: only the first png save attempt worked, it's a 2mn render at that point. The next Igi attempt messed the rest up. Also my PC hitting beyond the 8GB RAM limit and swapping to disk is a good excuse not to contribute, I even quitted explorer.exe for the whole render. Too extreme, I wasn't prepared.
SCHMUMS
Post by SCHMUMS » Fri Jul 19, 2013 1:12 am
C'est des choses qui arrivent tu n'y peux rien
Ne t'inquiètes pas je vais tenter de lancer le rendu sur ma machine une fois que j'aurais terminé le précédent.
olivier
Zbrush 4
Voytech
Post by Voytech » Fri Jul 19, 2013 1:22 am
I hate to throw out rendered stuff... here's 0250 with over 3800ssp https://app.box.com/s/exkgcepzpegrbaee92vn
Let me know if you need anything else today done on RT.
Post by CTZn » Fri Jul 19, 2013 1:24 am
Only the first png save attempt worked, it's a 2mn render at that point. The next Igi attempt messed the rest up. Also my PC hitting beyond the 8GB RAM limit and swapping to disk is a good excuse not to contribute, I even quitted explorer.exe for the whole render time.
SCHMUMS wrote:C'est des choses qui arrivent tu n'y peux rien
olivier
Trop extrême, je n'étais pas préparé à ça :/
SCHMUMS
Post by SCHMUMS » Fri Jul 19, 2013 1:25 am
Thank you so much!
should go for today ;) you already much!!!
Zbrush 4
