community need for renderings
Re: community need for renderings
it seems to me!
How you came to SPP?
Think you can calculate another image after?
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Zbrush 4
It's around 350ssp.SCHMUMS wrote:it seems to me!
Which one next?
doing 3369 now
- Polinalkrimizei
Going for 251_2!
Just did a complete reconstruction of my office and still need to confirm that my new wires can take all the equipment running at 100%
How much SSP are you goal!?
great guys!!!
ideally 500 SPP may be more (it depends if there is too much noise)
Zbrush 4
Zbrush 4
Voytec, can you send me your picture first calculated?
Zbrush 4
Zbrush 4
listing update more than 3
Zbrush 4
Zbrush 4
i'm beging 114210250
Zbrush 4
Zbrush 4
listing update
Zbrush 4
Zbrush 4
https://app.box.com/s/sb6vbp0xueqbf8ogctn0 this is 3380
3369 looks a bit noisy at 480ssp but here it is anyway: https://app.box.com/s/2jmltrerk7d1psoc8frk
Also, 3369 used light layers, which indigo RT does not allow.... not sure if it looks ok to you.
I can run 0250 run overnight but again, no light layers. Let me know asap as I'm about to leave work.
Mine (150653386_2) is already at over 900 Spp (Bidir) and still has got quite a bit of noise.
Next update is in 17h.
I'll stop after that and will post it (where ?). You can make the call then if you need it rendered somewhere faster.
Ok. Gotta go. I'm running 0250 in case you need it and it's ok without light layers.
You should be able to denoise the renders I uploaded earlier using Adobe Camera Raw.
Voytech
actually there is a trouble with the lights on the 3369. I'll take care.
On the 0250 I already calculate.
You can still charge you either the 114210252_4_hd either the 114210259_2_hd
Thanks!!
Thanks!!
Zbrush 4
Zbrush 4
Headroom,
can u send un screenshot of your rendering, to show the level of noise on the image
Zbrush 4
Zbrush 4
