MtI 3.6
ior
Re: MtI 3.6
Post by ior » Tue Jul 16, 2013 1:47 am
cool! :)
ior
Re: MtI 3.6
Post by ior » Wed Jul 17, 2013 7:53 am
The new version gives this error selecting diffuse materials when indigo editor is open and the indigo editor closes when selecting diffuse materials:
// Error: file: C:/Users/me/Documents/maya/2014-x64/scripts/mti_UI.mel line 486: Too many children in layout: rowLayout62 //
rowLayout increases number as I click in diffuse shaders
And when I try to render it gives this error and export freezes:
// Error: file: C:/Users/I/Documents/maya/2014-x64/scripts/mti_GEN_.mel line 479: No object matches name: difuseMaterialName.shc //
I am using a scene that worked well in previous version.
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 8:25 am
ah thanks I fixed this for the next update.
third line of that proc mti_UI_indigoDiffuse
replace (line 473)
rowLayout -nc 2;
by
rowLayout -nc 3 -cw3 120 140 80;
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 8:30 am
nah ignore the above, I kind of overlooked the indigoShader this time. Please use a lambert node for diffuse/Oren-Nayar materials meanwhile.
Thank you for the report.
edit: the fix also requires adding this line:
	mti_addAtt($mat,"bool","shc" ,"shadowCatcher","Shadow Catcher","","","0","");
into the indigoShader case in
proc mti_addAttr_mat (string $mat)
ior
Re: MtI 3.6
Post by ior » Wed Jul 17, 2013 10:01 am
I think Iv done everything correct and still gives the error when rendering:
// Error: file: C:/Users/me/Documents/maya/2014-x64/scripts/mti_GEN_.mel line 479: No object matches name: difuse1.shc //
The rest is fine.
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 11:20 am
If you have not restarted Maya you need to source back the edited mel file.
I'll get this sorted soonish, the fix was given hastingly.
ior
Re: MtI 3.6
Post by ior » Wed Jul 17, 2013 12:08 pm
of course, maybe I did something wrong.
I added in line 196 of mti_addAtrr.mel and it looks like this:
		case "indigoDiffuse":
		break;
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 12:19 pm
that's the same switch/case body we are talking about, but it should be in the indigoShader case a few ones below. The indigoDiffuse node was never published because I failed at OGL rendering. It should be an empty case, if at all.
Beyond this fix, export might well need some related updates too. Again lambert is to be preferred meanwhile.
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 12:24 pm
ah, I can't help but post bullcrap loads.
it's not even in the indigoShader case my mistake; just add the line at the very end of the procedure, below similar ones:
	mti_addAtt($mat, "string", "ppa", "profilePath", "", "", "", "","");
	mti_addAtt($mat,"short","lli" ,"lightLayerIndex","Light Layer Index","0","15",
I'm considering setting the shadow catcher on by default in the case that other materials would support it.
ior
Re: MtI 3.6
Post by ior » Wed Jul 17, 2013 1:40 pm
Now thing is ok but I am animating cauchyb (dispersion) and it says at export time
frozen: incorrect parameter
Textures can not be used to define a volumetric absortion (indigoMedium2_cauchyB1)
It is only some keys, not a texture.
Re: MtI 3.6
Post by CTZn » Wed Jul 17, 2013 10:43 pm
workaround: plug a spectrum node in and animate its uniform value.
fourzeronine
Re: MtI 3.6
Post by fourzeronine » Wed Jul 09, 2014 8:35 am
What version of maya does this work best on? I am trying maya 2015 and many things don't seem to work. So before I start installing all versions of maya to test, what version should I use?
fourzeronine
Re: MtI 3.6
Post by fourzeronine » Wed Jul 09, 2014 8:46 am
getting this error:
Error: file: mti_xml.mel line 94: No object matches name:
fourzeronine
Re: MtI 3.6
Post by fourzeronine » Wed Jul 09, 2014 9:10 am
I seemed to fix it. in mti_xml.mel
change:
global proc string closeTag()
	global string $currParent;
	string $temp[] = `listRelatives -parent $currParent`;
	$currParent = $temp[0];
	return $temp[0];
to:
	string $temp[] = `ls $currParent`;
	return $temp[0];
now you can link igs files in maya 2015! :D
Re: MtI 3.6
Post by CTZn » Fri Jul 11, 2014 2:44 am
isnt ls currentParent returning currentParent ? that being said off the top of my head... you know, when I started scripting I could only focus onto a few lines at once, and that's how I introduced the more bugs. but since I am not supporting that mti anymore, I do appreciate your efforts and am wishing you the best with it.
