Vlado's renders
Vlado's renders
Hello, I opened this thread like others to post here.
The model is from the net. Hope you like it!
Regards,
Vlado
Regards,
Vlado
Re: Vlado's renders
Try to put it into a studio setup, to tweeak the materials. In your scene its hard to see if they are right. The image also looks a bit oversaturated.
Re: Vlado's renders
I put it in a scene environment
) But can't get the motion blur working. I have only the wheels moving by now... May someone tell me how motion blur works in Maxigo.. Thanks in advance
Re: Vlado's renders
Enable motion blur and play with the shutter speed.
Re: Vlado's renders
Thank you, I'll try.
Re: Vlado's renders
It is not working. I set it to 8 seconds and it is the same. Does it work with 3ds max or only with other exporters because I think I saw only skindigo examples in the forum.
Re: Vlado's renders
Edit: I just noticed if the object is attached (child) in the hierarchy it won't have moblur. To check: press H, and select Display > Display children - If the wheels are parented by something they won't have motion blur.vl_dm wrote:It is not working. I set it to 8 seconds and it is the same. Does it work with 3ds max or only with other exporters because I think I saw only skindigo examples in the forum.
It works in IndigoMax if you don't want to change the parent/child hierarchy though it is only beta and you might find other bugs.
Re: Vlado's renders
Hello, this is my new wip. Only lighting and shading. I hope you like it!
Re: Vlado's renders
Good old AVP
All it needs is a twisting passageway with aliens crawling on the walls...
- zeitmeister
Re: Vlado's renders
Yeah!
- Polinalkrimizei
Re: Vlado's renders
I completely missed that one!
Great mood, the tinted water is awesome...
Users browsing this forum: Google [Bot] and 123 guests
