Maxigo 3.2.1 beta2 for Max 2012, 2013 (64bit only)
Re: Maxigo 3.2.1 beta2 for Max 2012, 2013 (64bit only)
hello to all i was woundering how to use presets in maxigo beta like in 3.0.7? any solution? i;am using max 2013 thx
I'm affraid not.
I didn't reach this far to add presets support.
A workaround could be to create a local material library with your common materials.
Suv
Suv
Hi Suvakas,
First, thank you for this plugin, after a week of experiment 3max 2012 and indigo 3.4.16. nvidia gtx 460m and cuda. I should say it's much convenient and stable than the "official plugin"why is not the official's one ?
Some questions:
I would like to be sure in 3dsmax Material Editor.
If the Glossiness is "exponent" and Dispersion is "cauchy effect" in indigo ?
You have sometimes a different way and often better way of thinking that the conceptor of Indigo interface 3.4.16
Request:
It will be lovely please, if you can give us some advices and tutorials about:
The subsurface scattering roll out (not seen anything about that)
and
The exit portal (the one existing in the forum are based on sketch up)
A way to not loosing the name of object and Material when we exporting ?
Bugs :
For now, I just noticed that if I set the sun with a different layer than 0, 3dmax will crash when I recall the render set up pop up , but it will render fine in indigo.
Thank you very much for your work Suvakas
Stéphane
Some questions:
Request:
and
Bugs :
Stéphane
Hi Stéphane,
Great to hear that Maxigo has been useful to you.
I've never liked too technical terms so I used more "artistic" ones where I could.
Suv
Well... initially Maxigo was the official one, but I was too slow updating it so I got replaced by a better programmer. New guy, new plugin.kiku70 wrote: First, thank you for this plugin, after a week of experiment 3max 2012 and indigo 3.4.16. nvidia gtx 460m and cuda. I should say it's much convenient and stable than the "official plugin"why is not the official's one ?
That's correct. Glossiness = exponent and Dispersion = cauchykiku70 wrote: If the Glossiness is "exponent" and Dispersion is "cauchy effect" in indigo ?
In Maxigo it's a modifier called "Maxigo-Exit portal". Add it to model you want to turn into portal.kiku70 wrote: The exit portal (the one existing in the forum are based on sketch up)
That's quite a bit of work. It's in my to do list thoughkiku70 wrote: A way to not loosing the name of object and Material when we exporting ?
Thanks. I'll try to fix it.kiku70 wrote: Bugs :
Suv
Hmm.. I'm unable to reproduce it in 2013. It's probably fixed already. I just have to make a beta 4 build for 2012 too.kiku70 wrote: Bugs :
Stéphane
[edit]
Made a build for 2012. See if it fixes the issue.
Suv
- MaxigoExporter64Beta4_2012.zip
- Try this...
- (195.4 KiB) Downloaded 899 times
Hi Suvakas,
Thank you for your reply
About the crash it still there with the new plugin,
What I should mentioned is that I set up the sun and sky with differents layers, my try was with sun layer 10 and sky layer 11.
Maybe that's not possible to separate sun and sky ?
So as I said it's render well but when I recall the render set up (F10) in 3dsmax , it crash anytime.
SSS rollout :
Sorry to ask again about the sss rollout do you have time to give us some explanations or where we can get a tutotial ?
Thank you in advance
Stéphane
Ps. For now, I don't think they hire a better programmer
a lot a of bugs with "the official plugin" they should rehire you
SSS rollout :
Stéphane
