problem with environment map and exit portals
lape
Post by lape » Fri Jun 14, 2013 4:11 am
I just tried to render a scene using exit portals. I also used an environment map. Without exit portals everything is fine, and my scene renders like it should. But when I use exit portals, the environment map turns black. I already read some posts from Pibuz who seemed to have the same problem with Skindigo http://www.indigorenderer.com/forum/vie ... 0&start=75) but whatever values I use for sun, environment map and emission: no chance :(
I also tried to export the scene and change the settings for the background settings via the property editor, but whenver I try to change anything, Indigo crashes.
What seems to work: Export the scene without environment map, and then use the property editor to load a new exr. If I do this, I can change all settings for the exr, but now I have no button to add the sun???
Any help?
24 hours isn't enough
http://www.werkraum3d.com
Re: problem with environment map and exit portals
Post by Whaat » Fri Jun 14, 2013 6:07 am
Try changing your rendering method and see if that makes a difference. If try using a Bidirectional method if you weren't before and vice versa.
lape
Post by lape » Fri Jun 14, 2013 6:21 am
I already tried every rendering method available. EXR always stays black when exit portals are active.... Im getting frustrated :cry:
It seems to be a problem with the emission values?
dag
Post by dag » Fri Jun 14, 2013 7:25 am
Flip normal on the exit portal plane.
lape
Post by lape » Fri Jun 14, 2013 8:25 am
there is no problem with the normals, this was the first thing I looked at.
Post by OnoSendai » Fri Jun 14, 2013 10:07 am
Hi lape,
I'll have a look at this soon (tmrw hopefully) and try and fix it.
lape
Post by lape » Fri Jun 14, 2013 10:19 am
that would be great! :D
Post by OnoSendai » Fri Jun 14, 2013 10:34 am
Hi Lape,
Is the problem occurring when you tick the 'Add Sun' checkbox in the SketchUp environment map settings?
lape
Post by lape » Sat Jun 15, 2013 7:36 pm
OnoSendai wrote:Hi Lape,
No, the problem also occurs if I only use the environment map for lighting. And it doesn't matter if I use "blackbody" or "uniform" for the emission. As soon as exit portals are active, environment map renders black. I already tried different exr files, but the result stays the same :cry:
Post by OnoSendai » Sun Jun 16, 2013 11:23 am
I think I have figured out the problem and fixed it. Fix will be in the next release (3.6.16)
lape
Post by lape » Mon Jun 17, 2013 7:13 am
OnoSendai wrote:I think I have figured out the problem and fixed it. Fix will be in the next release (3.6.16)
Thank you! :mrgreen:
Post by OnoSendai » Tue Jun 18, 2013 4:54 am
This should be fixed in 3.6.16: http://www.indigorenderer.com/forum/vie ... =1&t=12429
What I have done is make the exit portals use the emission scale from the background material.
So the background should now be the same brightness with and without exit portals.
lape
Post by lape » Tue Jul 02, 2013 7:54 am
OnoSendai wrote:This should be fixed in 3.6.16: http://www.indigorenderer.com/forum/vie ... =1&t=12429
Sorry, but I don't get it...I still get a black environment map. What am I doing wrong? This is driving me mad :?
I attached my simple Sketchup test model with exit portal and exr, perhaps somebody can try it and post a result with settings?
test ep.zip
(2.2 MiB) Downloaded 382 times
Post by CTZn » Tue Jul 02, 2013 11:19 am
The problem might lie into the scene since changing the map did not help.
Try scaling the faulty portal up and down, to test a full intersection with the walls and also no intersection.
Redo the portal geometry ?
If activating the portals into the scene means unhiding them, make sure that there is no duplicate geometry around.
dag
Post by dag » Tue Jul 02, 2013 4:35 pm
You need exit portals in both windows. Light only goes through exit portals if one is in the scene.
Users browsing this forum: No registered users and 109 guests
